CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL63 Brake rotor replacement.
Old Dec 2, 2015 | 06:20 PM
AMG 17GT's Avatar
R Nine T
So what is everybody doing after 35,000 miles with these rotors besides racing brake.?? I don't consider that option cost-effective and or any different than buying factory rotors wholesale.
So what is everybody doing here? Besides spending $2500 on two rotors?
Old Dec 3, 2015 | 02:43 PM
AndreNY's Avatar
couple of Benzos
if you need the rotors I have a set of Brand New ones
Old Feb 20, 2016 | 01:44 PM
AMG 17GT's Avatar
R Nine T
Still need rotors. Anyone?
Old Feb 25, 2016 | 01:20 AM
08CL63AMG's Avatar
2008 Mercedes CL63 AMG
bump, I'm curious as well if there's another solution.
Old Feb 25, 2016 | 05:17 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
On the CLS forum Someone had new friction rings custom built for two piece CLS63 rotors. Bud Wilkinson, a company called Colman, around $600 if my memory is working.
Old Feb 25, 2016 | 05:19 AM
Andy0331's Avatar
'08 CL63
Unfortunately, I can't recommend anything beyond Racing Brake. Great product at less than the replacement cost of OEM.
Old Feb 27, 2016 | 06:43 AM
sszgo's Avatar
CLS55 and CL63
http://www.carid.com/2008-mercedes-s...-brake-rotors/
Old Feb 27, 2016 | 08:48 AM
AMG 17GT's Avatar
R Nine T
Now that is scary
Old Feb 27, 2016 | 09:08 AM
cm60k's Avatar
Why not go with "CL65/S65/SL65" front brakes with 2-piece Rotors, less $$$ & less weight..!!
ZAYED,,
Old Feb 27, 2016 | 01:10 PM
sszgo's Avatar
CLS55 and CL63
Originally Posted by ROMEO550
Now that is scary
just change the car to CL, link provided was for S. it will show you various options well under 1000 bucks for a set for cl63 amg...
Old Feb 27, 2016 | 08:05 PM
fallen's Avatar
2014 E550, 2015 E63S, 2017 G63 - RIP
These are NOT CL63 rotors.
There is a huge difference between CL550/600 and CL63/65 brake rotors.
Unfortunately the only decent aftermarket option for CL63 is Racing Brake...
Old Feb 27, 2016 | 09:39 PM
sszgo's Avatar
CLS55 and CL63
Go in the options and you can select the cl63 and cl65. Not all rotors have the option for amg so browse the list a bit.
Old Feb 27, 2016 | 09:44 PM
sszgo's Avatar
CLS55 and CL63
For example this one at 730 bucks
http://www.carid.com/2009-mercedes-cl-class-brake-parts/centric-premium-brake-rotor-70002206.html
Old Feb 28, 2016 | 01:50 AM
sszgo's Avatar
CLS55 and CL63
what about rotors from other cars that have same bolt pattern and diameter / thickness ?
https://www.ecstuning.com/b-genuine-.../4g0615301ekt/
wolkvagen for example ? audi rs7 ?
Old Feb 28, 2016 | 01:52 AM
sszgo's Avatar
CLS55 and CL63
http://www.ebay.com/itm/AMG-SL-BS-55-63-65-brembo-discs-rotors-390x36-w211-r230-w219-w204-w212-w221/151995823162?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35626%26meid%3D35ac5f90d33c4a728efa02335d21b41a%26pid%3D100011%26rk%3D1%26rkt%3D1%26sd%3D151966713362
pair of brembos for 1600
Old Feb 28, 2016 | 01:54 AM
sszgo's Avatar
CLS55 and CL63
Old Feb 28, 2016 | 02:04 AM
cm60k's Avatar
Audi/VW uses same bolt pattern, but the center bore are differs than MB..!
yeah, those 2-piece Brembo's are good to go, but the Rotor height are differ than CL63/S631-piece Rotor,
CL63/S63 1-piece Rotor height is (60.5mm), while 2-piece Rotor is (64.5mm)..!
needs a little bit mods. to fit them, or can fit them directly with "CL65/S65/SL65" calipers..
ZAYED,,
Old Mar 1, 2016 | 03:31 AM
miloc204's Avatar
w204 amg
i have also rotors 390 one piece and 2 piece
let me know what you want
Old Mar 14, 2016 | 02:20 AM
cl63pappi's Avatar
CL63 AMG
Thanks for this! I've been sweating over this for awhile lol.
Old Mar 14, 2016 | 10:21 AM
AMG 17GT's Avatar
R Nine T
That's per rotor sir... Might as well go racing brake. Sane price.
Old Mar 14, 2016 | 02:25 PM
cl63pappi's Avatar
CL63 AMG
Fml of course it would be per rotor :/
(Alright, so where does one go to purchase the racing brakes? Do I need to modify the calipers?) *sorry I should have seen the link above. Thanks for pointing out the racing brakes!
Old Mar 15, 2016 | 04:08 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
"Fortunately" RB has light weight two piece rotors made for a 100% bolt on installation for CL63.
http://www.racingbrake.com/RB-Iron-R.../mb-irk-04.htm
Price is for the complete car kit (4 rotors including brake pads). Purchase from RB with confidence, or you can continue your search or try other source, but you may end up with the same decision as hundreds of other MB owners did and settle with RB rotors.
Parts are in stock for prompt shipment.
Old Jun 1, 2016 | 04:13 AM
jpastor's Avatar
CL63
Do you still have them?
Old Jun 1, 2016 | 04:14 AM
jpastor's Avatar
CL63
Yes, I will need rear rotors soon.
Old Jun 4, 2016 | 02:42 AM
miloc204's Avatar
w204 amg
i have rotors 390 for cl63 amg
if somebody needs let me know
