Thinking of purchasing an 08 or 09 CL63. Any thoughts or suggestions?
Anything I should look out for? Any one of those years I should steer clear of? I just started my research but figured I would give this forum a shot also. Many thanks in advance for your help!
I was thinking maybe one of these...
I, myself, bought 09 and it is perfect. Just make sure that suspension, especially shock absorbers are in good condition, brakes too (one rotor costs 1200 USD), so you don't face buying expensive parts. Also, check the ABC pump if it makes any kind of noise, as these things tend to go away quite quickly and cost a lot of money to replace - mine was replaced at 65k miles and costed 4k USD with labor. Other than that, I believe it should be all right.
Of course pay attention to any kind of weird noises coming from the car, check the transmission, it shouldn't be jerky, gear changes have to be flawless. Engine tends to be quite rough on idle, I learned it's normal.
I would look into 2009/2010, as it is the last year of pre-facelift version with 6.2 N/A engine. Newer versions are little bit more powerful, faster, but as I learned at Mercedes dealership here in Europe, the 5.5 Bi-Turbo engine is not reliable and they get a lot of car with many different problems.
Also, are you keeping the M4 or switching for the CL63?
Please don't change one mount lol.
As far as a CLS63 as an option, that's okay, but I would compare the CLS interior to an E class, the CL & S are on a different level of luxury than the others.
I'd possibly entertain selling mine (Blk/Blk, w/CF interior, appx 55,000 mi), but I'm out of the country until mid-April. I'm fighting the GTS bug...
Just terrible advice. This is mostly labor. When replacing engine mounts the flex plate and trans mounts are all right there. Probably $300 in parts.
You'll find out.....
GT for me...
He told me other ones are without any problem and there is just one that needs replacement?
