CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
GAS QUESTION 93 ethanol or 90 gas?
Old Oct 28, 2016 | 12:28 PM
biker349's Avatar
cl600
i have a 2004 cl600 twin turbo and have been using shell 93 octane ethanol gas, the shell station is also selling 90 octane pure gas. they say both have the same additives, except for the ethanol. is there any advantage, or benefit in using one over the other. the pure gas is about 10 cents a gallon more expensive. what are you opinions? this is my daily driver and i don't race.
thanks
Old Oct 28, 2016 | 06:50 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I would not advise using the 90 on your turbocharged CL. It does not have the needed octane rating/ knock resistance to protect your engine.
Old Oct 28, 2016 | 06:52 PM
Rainers's Avatar
Read your owners Manual. If it say 90 then 90 will do.
Old Oct 28, 2016 | 09:13 PM
Dr Matt's Avatar
05 CL65
I run 90 in my modded CL65 about 350 days per year (other days are on MS109). I am at WOT at some point almost every day, in temperatures ranging from 80's to -20's Fahrenheit. Only days my car is not in boost is when all my driving is on ice and there is no pavement on a drive. Running 90 in a CL is fine, you just have less performance. The computer will compensate just fine. If your CL was not set up for ethanol, I'd be more worried about the corrosive effects of Alcohol than the lower octane fuel.
Old Oct 28, 2016 | 11:02 PM
BlownV8's Avatar
It says 91 is the minimum.
Old Oct 30, 2016 | 05:50 PM
biker349's Avatar
cl600
thanks for the responses. aren't all 2000+ cl's and mercedes set up to run on ethanol? pretty much except for rare cases like this one shell station that's all you can find.
Old Oct 30, 2016 | 07:43 PM
BlownV8's Avatar
There are only a hand full of C class cars that are flex fuel compatible. No, they are not good with full ethanol.
Old Nov 1, 2016 | 09:04 AM
biker349's Avatar
cl600
thanks, i'm talking about the standard 10% ethanol at the pump.
Old Nov 1, 2016 | 09:18 PM
BlownV8's Avatar
Yes, they will all work with 10% ethanol just fine.
Old Jun 26, 2017 | 07:07 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
Ethanol is your friend.
Old Jun 26, 2017 | 11:11 PM
Geraldius's Avatar
'15 GLK350, '05 CL65 AMG, '04 C320 4matic
Indeed!
