Head unit "system unavailible" then shuts off
I've tried disconnecting the battery for 20 minutes but nothing changed.
Any recommendations on how to troubleshoot the problem?
I've read if anything in the fiber optic loop has gone bad the entire system will stop working, would using a fiber optic loop bypass help diagnose the bad part?
And also as far a replacing the amp, audio gateway etc will a unit out of a W220 S class work?
Thanks!
When i bought the car about 10 years ago it was still under warranty. The Mercedes dealer said it was a known problem but there were no known fixes (hate dealers). I assume that is still the case.
Hopefully i can remember V8mercedes solution and will try it the next time it occurs. That would be a great solution rather than waiting a drive cycle, but i can live with it if it doesnt. The key, over 10 years, it has not gotten any better or any worse.
So it is an issue but not a killer.
I'm just about at the point of buying all new speakers/amps/head unit and bypassing the entire system all together.
I've ordered multiple of the fiber optic bypasses from the Mercedes Benz dealership, I've bypassed my cd changer, Nav and what im assuming to either be the audio gateway or phone ( underneath the cd and nav, next to amp) as well as the amp even with everything bypassed at the same time the head unit loads up, now stays on longer than before, no sound very laggy and then "system unavailable" and shuts off. Also tried a battery reset with the bypass and nothing.
Any more ideas or help would be greatly appreciated.
is there a phone to bypass under the rear seat? found a Motorola box under passenger rear but no fiber optics leading to it.
Thanks -Dom
So this is the deal, all of the electronics are above the wheel and are supposedly protected by the wheel well. It's a terrible two piece design that's RIVETED together. So water got in and destroyed everything as the tube in well was clogged.
What made it worse is my car warranty declined coverage and then my car insurance declined as it was declared a design defect. I was fortunate that my service advisor convinced them I could not have prevented tube blockage ( and I was ready to litigate
, and they relented. All components were replaced and both wheel wells were sealed. I encourage all of you to check that area.
