Oh how good it is to be back in my CL65!
Anyway, I took it to a buddy's shop and they confirmed I had no refrigerant in the system, checked for leaks, it held vacuum and pressure, so they recharged it. Power was back and so was my cold A/C, for about 2 weeks and again no A/C because it lost all the refrigerant again. Still couldn't find the leak. Added dye a few times and it would loose pressure over time but neither they nor I could find the leak. Finally about mid June I found it. The valve that controls refrigerant flow for the Killer Chiller's drag option was leaking slowly. This is my second of these valves to fail BTW. So, as I didn't plan to drag race the car regularly anymore I decided to remove the valve/drag kit and replace all of the lines and fittings that came with the Killer Chiller that are held together with regular hose clamps with proper A/C rated permanent clamp style fittings.
Went to see another buddy who works at the only place locally that sells that type of fittings with the hoses off my car. We figured out what it would take to do it right, but the T fittings are not an item they stock so we ordered them....... in June..... Well, there was a problem with the supplier and in the end I finally got all the pieces to finish the car yesterday. Got it all put together last night. Taking it to get the A/C recharged today, hopefully for the last time ever.
So, I finally drove it to work this morning even without refrigerant, only about 5 miles to work, and oh how I've missed the CL! While the CL was down I bought a new truck (F350 dually 4WD 6.7L PSD) and modded it (a lot) including delete and tuned it. On the Rampage tune it it over 1,300#' of torque and about 650 hp. It feels amazing, for a truck. But OH THE JOY OF DRIVING A MODDED CL65! I have missed this car!
I haven't been on this site at all as I've been focusing on getting all the mods I wanted done to the truck so have been on the truck and diesel forums. Anyway, I'm back. Now time to decide what I'm going to do about an IAT gauge so I never loose track of keeping an eye on those IAT's again. The Areoforce was nice as I could see boost, IAT's, and a lot of other parameters not otherwise easily monitored, but A CL65 has enough reasons to be unreliable and I don't want another gauge that fails almost annually. Wish there was a reliable option to add the ability to monitor multiple things with only one gauge.
In regards to the Diesel truck, I know what you mean. My Dodge Cummins truck has so much torque it is a real beast. I sometimes wonder if something like the CTS2 gauge system for the diesels would work on the CLs. It gives you a nice big screen and the ability to monitor many items at one time.
Anyways, glad to have you back on the forum.
It's hard to explain to someone who has never driven an M275 what it feels like. Puts a smile on my face every time. BTW, enjoy that truck! My daily driver is a tuned and deleted F250, as well. I don't think I can go back to anything with less than 600hp, again.
Truck pic taken right after unloading the new race car I'm building at the shop that is doing my 8.50 cert chrome moly cage. This car's HP number will not be a 3 digit number...
So far the Killer chiller has been awesome, except for the failure of that valve which is only present with the Drag kit. I did have to figure out that when it is cool outside the A/C doesn't cycle on my CL unless you turn on the defroster. Sucked being at the track on a cold day in the fall looking for a PB and my IAT's were higher than on a hot day in mid summer. Missed out on running PB because I couldn't figure out why it wasn't working until too late.
Do you have a datalogging setup? Not the same as a boost gauge, but you could see your IATs. I should but I don't.
As far as the Fairmont, I thought stock they dyno around 95WHP. Its crazy to think the HP won't be a 3 digit number I guess it depends on the engine option. I would have thought a K&N would have got you close to another 6HP. You go from one extreme to the other, you must be something to talk about in Alaska. Mercedes race car, brand new high powered modded truck and a low powered Fairmont "fuelie". Wheel skirts, soft acceleration and lots of coasting will really help with your MPG. Also, the tires look too wide in the back.
I had been using a Aeroforce Interceptor gauge to watch IAT's, but have switched to a DashCommand setup as I had 3 of the Aeroforce gauges fail between my Lightning (1) & my Mercedes (2). As far as the Killer Chiller in a hot climate, I think the CL has enough cooling capacity to do fine even in a hot climate since we have the same A/C system as an S65 which has a second evaporator for the rear seat.
Wheel tubs and custom coil over rear suspension along with the narrowed 9" are going to allow even bigger rear tires on the Fairmont.
Do you have the partno to the weistec kit you installed?
BTW, I kinda knew the direction you were going with HP on the Fairmont, I was just attempting to be funny.
Yeah, just too busy working and snow plowing lately to mess with the CL. This weekend I'm going to dive back in to finding the problem. Looks like the snow is going to stop falling for a while... hopefully.
