Transmission screech?
Here is a video at the end you can hear the sound I am talking about:
The first video you can hear it quite well and compare to the 2nd one, it does happen right after the tires spin so just maybe its the sound the tires make when they are slowing down from spinning?
first video:
second video:
It is still the same screech sound I have always said but the way it does it in relation to the gears I'm in.
So what I did was this in all clips I floor it from 1st gear and I let go of the gas all the way right before it shifts and thats when the sound is the loudest, in another clip I let it shift to 2nd I let go of throttle and it barely makes the sound. The last clip is from the outside I believe I let go in 1st gear thats why its that loud.
Another thing to note is I did some donuts and it does not make the sound I did them in first gear shifted to 2nd back to 1st and no sound I peeled out and no sound, it only does it in a straight line if I just let go of the throttle after hammering it. To understand better you can keep an eye on the RPM's. Its so hard to tell because maybe letting go of the gas and the tires gripping is the sound it makes that would explain why its louder in 1st gear since the tires and spinning faster and in 2nd they already have more grip but at this point even my friend who was in the car with me said it could be the trans, let me know what you guys think. btw check engine is cats
Rick
https://youtu.be/EMxIZGUf8-Y
Rick
Martin, your engine must idle to check the tranny oil level
