CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL63 AMG Updates
Old Nov 12, 2023 | 12:46 PM
ImaNoob's Avatar
2012 CL63 AMG
CL63 AMG Updates
The hood on my 2012 CL63 AMG has been fading really bad. I performed many searches for a Carbon Fiber replacement , with ZERO luck! Even reached out to a few manufacturers for CL63 Carbon hood - each one replied nothing available. If I had a CLS63 i'd be in luck, but nothing for a CL63... DAMN!
Next best thing to fix this fading hood was to get it wrapped in carbon fiber. Actually it came out better then I first thought it would (see attached photos). I've also gone and had the calipers painted/cleared in sublime green, wanted to do something different to make the car stand out. Got many compliments on them. Next up is the custom license plate that on order - AMG2NV.
I've gone and ordered a set of NGK 97506 (one step colder plugs) along with (8) coil packs that should be installed this upcoming weekend. Just waiting on the cross drilled/slotted rotors and pads to show up so can do all the updates as once. I'm still plan to remove the mid-resonator along with getting a Tuned Mercedes ECU calibration (dongle shows up Monday 13NOV2023). Once the dongle arrives will be able to have few calibrations for the CL63.
Don't find many CL63 that are modified, so I've started a tiktok page : CL63_2NV to start making videos of all the mods as I go. Picked up a dragy motorsports as well to get a base line - either i'm frying the tires or bogging it down. Best 0-60mph totally stock is 4.69 seconds. Not bad for a 5000lbs (with driver) pig!
Carbon fiber wrapped hood on CL63 AMG
Sublime Calipers
Front Caliper painted sublime green
Rear caliper painted sublime green
Dragy unit from 2012 CL63 AMG (stock no mods, has Weistec Air filter). Baseline run, 0-60MPH
NGK 97506 plugs, (8) coil pack along with tools to gap plugs, and install
Old Nov 13, 2023 | 12:52 PM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
Just replaced coils on my '13. One was bad I believe. Smoothed things out a little and made for a nicer low rpm pull. Enjoy, they sure are nice cars.
Old Nov 15, 2023 | 02:53 PM
ImaNoob's Avatar
2012 CL63 AMG
Looking to get this done this coming weekend.
Old Nov 15, 2023 | 03:04 PM
ImaNoob's Avatar
2012 CL63 AMG
Was able to finally get a 1/4 mile pull in the 2012 CL63 AMG. The 0-60 is slower then my best but will gladly take a 12 second run at 116mph. Still learning how to drive the car off the line. I can’t get over how fun this car is to drive. Car only has Weistec Air Filters and weighs 4995 lbs with me in it! Just need to get better traction and should be alot quicker.
Old Nov 16, 2023 | 02:58 PM
kpuri's Avatar
190E 2.3-16v | C43 | CL63
Are the "AMG" Logo Sticker/Decals or did you have them painted black?
I'm having trouble locating the correct size stickers/decals.
Old Nov 16, 2023 | 07:10 PM
ImaNoob's Avatar
2012 CL63 AMG
Had the AMG stickers reprinted in black material. After they were installed a few coats of clear went on top of the calipers.
Old Nov 20, 2023 | 12:46 PM
kpuri's Avatar
Can you share a website on the reprint or was this something you reprinted?
I need a set in Black front and back.
thanks!
Old Nov 20, 2023 | 08:50 PM
ImaNoob's Avatar
2012 CL63 AMG
thanks!
The same shop that installed my carbon fiber wrap on the hood, printed the stickers.
