We installed the Lorinser LM5 wheels from my 03 cl55 on my friends 06 S65 and the rears stick out. Do the 55 and 65 have diffrient rear wheel offset? Even looking at the factory 65 wheels i notised that compared to the factory 55 wheels there is alot less lip.
Quote:
so is it the rear end thats diffrient or the rear brakes. I would think that since both cars are amg they would have the same rear.Originally Posted by hyelifeCL
44 VS 60.
Quote:
You seem not to like the answer you got, but it's (mostly) right. The CL55 rears have a 46mm offset (non-AMG models with the sport package are 44mm), but S65 rear wheels are ET 60.Originally Posted by anton28
The rear suspension setup is different.
BTW, all front wheels on staggered setups, non-AMG sport models, 55s and 65s, have a 44 mm offset.
Another BTW is that the 65 has a wider track, front and rear, by 4 mm than all other W220s, including 55s. There are quite a few detail differences in suspension parts that are not obvious.
What, exactly is different on the suspension?The rear suspension setup is different.
Vic55
Administrator
close
- Join DateNov 2001
- LocationTHE Orange County, California
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2024 C8 Z06- 2025 BMW CS- 2022 Porsche 992 GTS
Liked:901 Times in 573 Posts
I had the same issue with my CL65- I wanted a nice lip and the offset sucked. Its the hub that sticks out more on the CL65 than its smaller brothers 600 and 55.
so before i ask, i know that this would be a step back so please lets save the coments
what would you need to change in the rear in order to be able to have the
cl55 offset. As funny as it sounds i would purchase a cl600 and not a 65 if i couldnt put a set of wheels on it that i wanted.
I assume you would need to start by downgrading the brakes to make room. The drive shafts are different, and might be part of why the spacing is different and the track is wider. You might therefore need to swap out the rear end and go to the non-reinforced version used on the 600. Assuming you can then align the car to 600 specs, you would have reduced the rear track by four mm, and would need to do surgery on the front as well or the car could be very unstable. My guess is that you would need to downgrade the front brakes and stub axles are realign the car. At that point the ABC tuning will be off, because it has been modified to work with the 65 chassis. You would need to reprogram the ABC computer with the 600 program as well, and possibly other telematics like ESP, which are fairly sensitive to chassis geometry.Originally Posted by anton28
These are all guesses, though. For a definitive answer you need access to MB parts diagrams and alignment specs.
If the look of your wheels is the most important thing for you and you can't find suitable wheels for the 65 chassis, a 600 would be a much better solution.
ExploreAMG 17GT
close
- Join DateMar 2006
- LocationATLANTA
- Vehicle(s) I driveR Nine T
Liked:711 Times in 539 Posts
Originally Posted by whoover
I assume you would need to start by downgrading the brakes to make room. The drive shafts are different, and might be part of why the spacing is different and the track is wider. You might therefore need to swap out the rear end and go to the non-reinforced version used on the 600. Assuming you can then align the car to 600 specs, you would have reduced the rear track by four mm, and would need to do surgery on the front as well or the car could be very unstable. My guess is that you would need to downgrade the front brakes and stub axles are realign the car. At that point the ABC tuning will be off, because it has been modified to work with the 65 chassis. You would need to reprogram the ABC computer with the 600 program as well, and possibly other telematics like ESP, which are fairly sensitive to chassis geometry.These are all guesses, though. For a definitive answer you need access to MB parts diagrams and alignment specs.
Interesting. I tried to ask this question in a cl65 thread, and maybe you could clarify.
The cl65 had brabus monoblock vi wheels. I have a meager cl500 with sport package. I was told the wheels wouldnt fit because of offset. They were originally on an 07 sl550.
Your logic suggests the cl65 is harder to fit and thus if those wheels fit on a cl65 than most certainly they will fit on the cl500, correct?
Ty in advance for clarity.
Paul
Paul
No. All that we can say is that the correct rear offset for a CL65 is 60 mm and for the CL500, 44 mm (assuming we're talking about 19" wheels). Correct offset for an SL550 rear wheel is 9.5 X 19 ET 31 or 10 X 19 ET 28. Assuming the wheels were close to correct for the SL, they have too low an offset for any CL.Originally Posted by ROMEO550
Your logic suggests the cl65 is harder to fit and thus if those wheels fit on a cl65 than most certainly they will fit on the cl500, correct?Ty in advance for clarity.
Paul
AMG 17GT
close
- Join DateMar 2006
- LocationATLANTA
Quote:
Ok so why am i seeing 20's on a cl65 with the big brakes and big suspension fit, and they wont fit on a cl500 with the sport pack?Originally Posted by whoover
They never looked right on the sl anyhow. I called Brabus and they claimed my size were correct. 19X 8.5 and 19X 9.5.....
You are right i have the 19's., so I am confused.
Quote:
Because the CL65 and CL500 take rear wheels with a different offset. Take it up with the AMG engineers. They moved things around in back on a 65 so that more of the wheel needs to extend inboard from the face that mounts to the hub than on the stock CL. I don't know why they did, but they must have had good reasons. So if you put a wheel meant for a 65 on a 500 it will rub on the inside. If you put a wheel meant for a 500 on a 65 it will stick out past the fender. More importantly, the wrong offset means the tire is not contacting the ground where it's supposed to, and will affect handling, tire wear and put strain on the suspension. Offset is determined by the engineers, and must not be ignored.Originally Posted by ROMEO550
Maybe you don't know that offset is that third number. 8.5 X 19 ET 30 and 8.5 X 19 ET 60 wheels are both 8.5 X 19 and will look identical at first blush. But the mounting surface will be about an inch further in on one that the other. That's because they have offsets that are 30 mm different. All three numbers have to be right. The first two don't tell you enough to know if it is a proper fitment for your car.Originally Posted by ROMEO550
They never looked right on the sl anyhow. I called Brabus and they claimed my size were correct. 19X 8.5 and 19X 9.5.....You are right i have the 19's., so I am confused.
AMG 17GT
close
- Join DateMar 2006
- LocationATLANTA
Quote:
Ok ty for explanation. Originally Posted by whoover
Obviously, I was hopeful they would fit.
Anyone in the market for 2 piece Monoblocks? P.M. if interested.
paul
well that sucks, because to me the only set of wheels that looks good on a w215 are the lorinser LM5's. Cant put those on the 65 with out them looking goofy and that sucks.
Sucks for my Monoblock VIs too, I was someday considering moving up from the 55 to the 65 and just keeping the big footwide tires. I may have to rethink things . . .
AMG 17GT
close
- Join DateMar 2006
- LocationATLANTA
Quote:
SO YOU HAVE THE MONOBLOCKS ON YOUR CL55?Originally Posted by Patentmat
NOW I AM TOTALLY CONFUSED.
HAHAHAH WILL THEY FIT ON MY CL500 OR NOT!!
AMG 17GT
close
- Join DateMar 2006
- LocationATLANTA
Well to clear the air, I just called Brabus and they will fit on the cl 500. My wheel has a 45 offset so it works.
Hope this helps anyone else.
That's great news. I hate to keep this issue going - but don't you need flared fenders to get them to squeeze under? My tires are TIGHT in the back, two, no three sheets of paper at the most for the wheel to tuck up into the fender
AMG 17GT
close
- Join DateMar 2006
- LocationATLANTA
Well you have 20s and mine are 9.5 in rear. Brabus said to use 275 35 on rears. Maybe you can go to 295s and get a little extra space.
Anyway we obviously love the wheel and i am glad it works for both of us.
Quote:
Hahaha - Never! Originally Posted by ROMEO550
They may be tight but they still fit.
I think that the OEM CL65 wheels are very very nice and would not change them at all if I had a 65.
I am having a problem finding some replacement rims for my 2006 cl65. Most of the rims out there don't fit.. Anyone have any suggestions of some good looking rims that work?
I reading some inconsistent messages on the offsets and sizes?? The originals are front: 19x8.5 offset 44mm and the Rear: 19x9.5 offset 46mm.
Is it different and what sizes can I change to without damaging the car and incurring more headaches???
I have a CL55 and just bought stock SL65 wheels (the ones that are either titanium or silver with bolts and twin spokes). They were from a SL55 and fit that car fine. I thought they would fit my car but it looks like the offsets are off. Does anyone know if I can have the wheels milled to correct the offset? It seems there is plenty of meat where it attaches to the hub and there is plenty of clearance for the calipers. Any suggestions would be helpful, even if it means selling them and starting fresh. Thanks.
