CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC Failure
Old Oct 14, 2012 | 11:12 AM
xabo's Avatar
'20 S63
ABC Failure
Went out this morning for some "spirited driving." After about 15 minutes of driving saw white smoke in rear view mirror. Then I saw white smoke coming from front of vehicle from under the hood.
Pulled over raised hood, sure enough smoke everywhere. First thought was coolant leak as I saw wetness on driver's side of engine and smelled fluid burning.
Made it home, raised hood and she's really smoking now, flames and all. Extinguished flames, looked at front of car and saw this:
Don't ever remember sitting this low.
Started car, the front started to rise and saw this:
Had the car since March of this year. Will CPO warranty cover cost of replaceing pump and system flush?
Old Oct 14, 2012 | 11:33 AM
Guilty's Avatar
'16 C63-S
That's sad! Only 35k miles? They better fix it for free since it's still under warranty
Old Oct 14, 2012 | 11:56 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Notify NHTSA. A hose blowing and causing a fire should be reported. The NHTSA recalled a hose on the 215 CL for just such a reason. However, the recall didn't go far enough in my opinion.
Old Oct 14, 2012 | 12:15 PM
xabo's Avatar
'20 S63
Thanks for the replies.
Please forgive my ignorance but how would I go about reporting this NHTSA?
Old Oct 14, 2012 | 12:47 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Hope you get it fixed for free. Good luck.
https://www-odi.nhtsa.dot.gov/ivoq/
Aaron
Old Oct 16, 2012 | 10:19 AM
xabo's Avatar
'20 S63
Dealership states failure due to "o-rings being dry rotted" and that the o-rings are not covered under CPO warranty. WTF?
Car was purchased in March of this year and has 35,000 miles.
Old Oct 16, 2012 | 12:25 PM
awiner's Avatar
2003 CL55 AMG
OMG, I hope it didn't take the ABC pump out with it.
Old Oct 16, 2012 | 01:03 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
That should be covered under the warranty but the $0.05 washer won't.
R.K.
Old Oct 16, 2012 | 02:26 PM
alx's Avatar
alx
oh, that is a new one....
the creativity.....
Old Oct 16, 2012 | 02:28 PM
xabo's Avatar
'20 S63
SA states that o-rings, gaskets etc. are considered maintenance items. I asked at what service intervals am I supposed to disconnect ABC pump and inspect the o-rings?
Contacted MBUSA and spoke with manager. Will be replaced under CPO warranty as a line replacement.
Old Oct 16, 2012 | 02:40 PM
BlownV8's Avatar
I wonder if that dealer was going to charge you and also claim under CPO warranty to MBUSA? Wouldn't put it past a dealership to do so.
While you were in there did they recommend to change the blinker fluid and spark plugs to the unobtanium tipped ones? Glad you did not accept that BS!
Old Oct 16, 2012 | 03:37 PM
Guilty's Avatar
'16 C63-S
What are the o-rings???
Old Oct 16, 2012 | 08:50 PM
WHTEVO's Avatar
That's great that you ended up getting it covered. Let us know how it goes.
Aaron
Old Oct 17, 2012 | 01:21 PM
Guilty's Avatar
'16 C63-S
Can someone please answer my question?
Old Oct 17, 2012 | 01:31 PM
awiner's Avatar
2003 CL55 AMG
An O-ring, also known as a packing, or a toric joint, is a mechanical gasket in the shape of a torus; it is a loop of elastomer with a disc-shaped cross-section, designed to be seated in a groove and compressed during assembly between two or more parts, creating a seal at the interface.
The O-ring may be used in static applications or in dynamic applications where there is relative motion between the parts and the O-ring. Dynamic examples include rotating pump shafts and hydraulic cylinder pistons.
O-rings are one of the most common seals used in machine design because they are inexpensive, easy to make, reliable, and have simple mounting requirements. They can seal tens of megapascals (thousands of psi) of pressure.
O-Rings are used in all the lines where they interface or mate with components to avoid leaks.
Old Oct 17, 2012 | 03:00 PM
Guilty's Avatar
'16 C63-S
Thanks awiner but I still don't understand
Old Oct 17, 2012 | 03:33 PM
slonar21's Avatar
CL600 2003
it's a rubber gasket, in a circular shape.
Look here
https://www.google.com/search?q=o+ri...w=1347&bih=875
Old Oct 17, 2012 | 03:37 PM
slonar21's Avatar
CL600 2003
Old Oct 17, 2012 | 10:30 PM
Guilty's Avatar
'16 C63-S
Thanks guys! So what kind of maintenance this thing needs?
Old Oct 17, 2012 | 10:51 PM
NRL's Avatar
NRL
CL65, FJ80, Sportsmobile 4x4, Model X Plaid
I've never heard of this O-Ring.. which specific one?
Old Oct 18, 2012 | 07:28 AM
alx's Avatar
alx
If you mate together two metal surfaces alone they will not be air/ water tight. You need something in between them to make them air/ water tight. You can glue them together, but you can't take them apart nicely after that. You can put special paste- but it gets messy. Or you can put rubber or cork. Those are called gaskets. Rubber o-rings are just that- round gaskets for mating hoses and pipes.
They are not wear item and they are supposed to last the life of the vehicle. In reality it does not work so and leaks (or blow-outs in the case of abc) develop.
Old Oct 18, 2012 | 08:59 AM
xabo's Avatar
'20 S63
Car was repaired under CPO warranty but not without a fight. The SA wanted to charge me $490 to replace the drive belt and steam clean the engine as it was contaminated with ABC fluid. I said that said contamination was a direct result of the failure which was covered under warranty. He said belts are not covered under warranty.
Contacted MBUSA again and got the issue resolved. Unf^&*ing real.
Old Oct 18, 2012 | 09:02 AM
Guilty's Avatar
'16 C63-S
Your SA is such a douche. You should find another dealership that appreciate you as a customer. Did you buy the car from the same dealership?
Old Oct 18, 2012 | 09:32 AM
xabo's Avatar
'20 S63
AGREED........this is my 4th Benz and the only one I didn't buy from them.
I've had all of them serviced there in the past. The shop foreman is very knowledgeable about Benzes especially AMGs. He's the only reason I go there.
Old Oct 21, 2012 | 09:35 AM
Petej's Avatar
2013 Audi S4 Stasis, 2013 Audi TTS, 1996 C3500 Dually, 1967 442, 2005 CL65-Sold, 2006 E320 CDI-Sold
It is because of this type of service that had me questioning if I should buy a Benz. At times I have considered if this will be my last. I know that there are good dealers and bad but if MBUSA cared they would take action on the bad service advisors/dealers that condone this type of action.
