CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC issue maybe an odd one
Old Dec 8, 2012 | 08:51 PM
driveability's Avatar
Cl65 AMG
2005 CL65 100k
No warning lights involved, noises etc.
Mostly original ABS parts as far as I know.
Driving on the freeway at freeway speeds feels to me as the left rear shock/strut shoots up and back down, quickly approx 1-2 seconds at the longest duration. Has not happened at lower speeds and I'm not sure if I'm going over 67 mph. Really an uneasy feeling, like its tipping over LOL.
Old Dec 8, 2012 | 09:24 PM
awiner's Avatar
2003 CL55 AMG
I have had this happen. The most common issue that causes this is the rear accelerometer. There was a recall on the two front accelerometers a while back but not on the rear. Needless to say, the rear was a problem for me and replaced which fixed these issues.
The issue is dangerous as it can move you over a lane in the blink of an eye. It can also slam a rear side down onto the tire in some cases.
If this happens to you while driving, use the height switch and raise the suspension to the highest setting.
Old Dec 9, 2012 | 12:18 AM
Cl65 AMG
Thanks for the advise, its a bit of a shock no pun blah blah blah ! My wife about craped her self LOL. I'll be looking to do some more research. I am assuming the accumulator pressure valve is blipping or something open and pressurizing the strut. I had a V8, 500 hp 914 that broke a trailing arm bolt during a hard acceleration at 70 mph. When I let off the car felt like it was going to flip over. That almost made ME crap my pants !!! Out comes the check book
I would think the first thing logically speaking would be a hight sensor going a skew, That would be great but ABC issues don't seem to go the painless route.
Old Dec 9, 2012 | 05:42 PM
Cl65 AMG
Exclamation Hoping for more input
It's not that I don't think the accumulator is the issue, just looking for some others who have maybe had a similar problem. I guess often things are repaired but there is more than one part installed in-order to isolate an issue and its left out in the thread ...
I'm having a hard time seeing the accumulator only effecting one strut the left rear.. HST its not real easy to be sure what is moving up and down while driving. What I think is happening may not be correct..
Old Dec 10, 2012 | 02:33 AM
Cl65 AMG
I am going to switch the rear level sensors tomorrow. Maybe that will help me with the issue.
still hoping someone has more to add.
Old Dec 10, 2012 | 12:23 PM
awiner's Avatar
2003 CL55 AMG
Im pretty sure your going to find out its the rear accelerometer which is a pain in the access to since its under the rear parcel shelf.
At anyrate, I have known a few other CL owners that have had this issue and the accelerometer was deemed to be the issue.
If your height sensor was out of whack, it would effect both sides equally not just one.
Old Dec 10, 2012 | 05:09 PM
Cl65 AMG
I read the above posts as an "accumulator" Ya just skimmed over the word "accelerometer" That sounds good.
Ordered part from Foothill Ranch Mercedes Benz, approx $215.00 Should have it in a few days.
Old Dec 10, 2012 | 09:57 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
I have a simular thing going on but it only happens if I am accelerating really hard and I hit a dip in the road; its as if the suspension wants to level the car. It feels really wierd when it happens. It makes it hard to steer the car because the steering wheel isn't straight anymore until the car level's itself again. Is this the same issue you are feeling/having?
R.K.
Old Dec 10, 2012 | 11:14 PM
Cl65 AMG
R.K.
could be, my car feels like it tilting from the driver-side rear and does throw off the steering feel a lot.
Old Dec 10, 2012 | 11:28 PM
radride's Avatar
Mine feels like the passengers rear part of the car raises up.
R.K.
Old Dec 14, 2012 | 11:43 PM
Cl65 AMG
i installed the new rear accelerometer and its been good for about 75 miles.
Old Dec 15, 2012 | 12:53 PM
awiner's Avatar
2003 CL55 AMG
Keep us updated. I know this fixed my issue which was the same one you were expirencing. All the sensors (Body Acceleration sensors both lateral and vertical, Turn Rate Sensors, etc) all work in unicen to control ABC. If one starts to go south, crazy things happen.
Old Dec 15, 2012 | 02:19 PM
radride's Avatar
^^Did you replace the rear one or the front 2?
I just ordered 2 sensors and will replace the fronts to see if that fixes my problem. If not, I will buy the third one and replace the rear one.
R.K.
Old Dec 15, 2012 | 06:48 PM
Cl65 AMG
R.K.
I only replaced the rear accelerometer, and theres only one to replace just to be clear.
It didn't make clear sense to me how it would seemingly effect only one rear strut so I was and still am not convinced but getting there. I've driven the car over 100 miles with no problem.
Old Dec 20, 2012 | 02:49 AM
xplosiveg06's Avatar
Mini Cooper, M5
does the accelerometer issue include the s55? after i installed my lowering links my car has done this on a few occasions. i feel like its coming from the front left. or could a damaged ride height sensor cause this behavior as well?
Old Dec 20, 2012 | 10:02 AM
radride's Avatar
^^I ordered two new ones for the front. They are a lot easier to replace. I will try it out in the spring and see if that solved my issue. If not, I have 2 sensors from the front that I can use and try in the rear. All of the 3 sensors are identical.
R.K.
Old Dec 20, 2012 | 12:21 PM
awiner's Avatar
2003 CL55 AMG
Yes, certain years of S55 production were too on the recall campaign for the front sensors.
awiner's Avatar
2003 CL55 AMG
R.K.
Yes, they are the same.
Old Dec 23, 2012 | 05:50 PM
Mini Cooper, M5
R.K.
are the accelerometers and the ride height sensors the same thing ? if not what do they look like?
Old Dec 23, 2012 | 05:52 PM
radride's Avatar
They are different. I am not sure what the other part looks like.
R.K.
Old Dec 23, 2012 | 09:33 PM
Cl65 AMG
Driving in a parking lot at slow speed 10 mph felt the left rear corner move down a bit and up sharply.
Still doing it.
Had driven the car a few hundred miles between incidence's.
Old Dec 23, 2012 | 11:07 PM
Mini Cooper, M5
R.K.
where are the two front accelerometers located?
Old Dec 24, 2012 | 09:57 AM
radride's Avatar
There's a link in Post 15 of this thread to the location:
https://mbworld.org/forums/cl55-amg-...lerometer.html
R.K.
Old Dec 29, 2012 | 12:26 PM
joshark's Avatar
S63 Coupe and GLES 63
I had a similar problem with my left front sensors they were vibrating and making a clanking noise. MB covered it under warranty on my 2011 CL 63.
Old Dec 29, 2012 | 04:40 PM
Cl65 AMG
Just drove approx 600 miles, still acting up. I think the sensors are all the same ? ? If so I am going to switch out one of the front ones with the likely good one from the rear I just replaced. Just have to drive it a bit and report back...
R&D
