Rear Accelerometer
To remove the rear accelerometer do you remove the rear seats & upper tray or go in from the trunk ?
I have the back seats out but not the upper tray, still trying to figure how to remove it. Those darn head rests are doing there flip flop LOL.
My wife wont drive in the car anymore (maybe not a bad thing), it just scared her death when the car started raising & lowering the L / R tire . The first time it happened to me was a shock as well.
R.K.
I will run the WIS document for you tomorrow with the factory way to replace. PM me your email address and I will forward it to you once run.
The older sensors look a bit different then the new ones that replace it. The new sensors are the same as the ones used on the front towers. I am not sure when the switch was made from the older rear to the newer rear sensor. The new part # is A0045423518
Sent a Pm
In the diagrams its located in the rear passage side but thats all I have.
I have done a lot of surfing looking for the information. with little to show. I guess it looks similar to the ones under the hood on the shock towers. I have got one coming in a few days.
Is it under the rear seats or behind the seats? If its behind the seats, when you take the trunk liner out you will see the back of the seats.
R.K.
I did try to remove the head rest but found I didn't need to. I did have to tear some of the insulation but it will fit back in well. Not able to get from trunk as there is a shelf that keeps ya from getting near it.
The second picture is of the drape behind the center rest, you can see the pins to which ya need to remove to reveal the above center nut. There are two on the outside at the bottom of the seat back you can see when you remove the seat bottoms. Seat bottoms have a spring loaded button at the front edge center you squeeze to remove those seats.
I drove the car without the sensor plugged in and the red dash light came on along with the cars suspension turning into a marshmallow. I then plugged it back in and the car never acted up again humm well I will install the part when I get it.
How do you release the drape part? How does the upper deck lid come unfastened? Is there screws holding it on or just tabs?
I think I'm going to order mine as well and replace it in the spring. My cost on the sensor is 126 bucks. I might take some pictures when I take the seats out for documentation purposes.
R.K.
The recalled sensors will have one of the following week codes:
06 W 20
06 W 21
06 W 22
06 W 23
06 W 24
06 W 42
See: http://ww2.justanswer.com/uploads/eu...ampaign_no.pdf
R.K.
My guess is that if a VMI was run on your VIN, and there are no OPEN campaigns, all campaigns must have been completed and closed.
Did you ask that they run a VMI to determine this ?
R.K.
R.K.
About 5 years ago dealers stopped handing this information out to customers for some reason.
There was also someone offering to run these inquires here: https://mbworld.org/forums/c-class-w...-them-you.html
I will pm you my VIN.
Thanks,
R.K.
I guess the rear mounted accelerometer ( apparently it looks at the vertical movements) did the trick.
Going to Las Vegas soon approx 300 miles should be fun !!!!
I did get a blip at low speed on the same side of the car (left rear). I did "switch" the rear level sensors,(at the same time I replace the accelerometer) so its not likely a level sensor since it acted up on original side. Thinking about my next step as I drive the car and hopefully keep acquiring data. Last edited by driveability; Dec 24, 2012 at 05:52 PM. Reason: update
