FYI Cutouts, I really like the sound
I installed some electric cutouts and in my opinion the car sounds great. I could take a video but the quality of the sound never sounds like the exhaust in person. The CL65 (2005) as you know don't come with resanators so its factory cats and mufflers. I dumped them just before the rear control arms. Its no $ 5,000 dollar exhaust but sounds great, not at all like my many SBC V8s.
PLATINUM SPONSOR
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Mercedes CL55
Which unit did you get? Also are you using the supplied remote or did you program the garage remote button to open the cut out flaps?
I not a fan of the remotes, I wired it using the cig/circuit and found a surplus sun-roof switch (Honda) which is easy to control without looking at it. I'm going to mount it near the front seat storage bin. I got the 2-3/4 inch units. The Y pipe fit was a bit loose (1/8")but was no trouble welding in that small gap. I haven't installed any down pipes as yet. I got the ones that have slotted alignment groves so adjusting clearances was easy.
