V12TT intake tubes: RaceHorse Version
Driver's side
The grille in progress.
Passenger side
What material did you use as your grill insert and how do you open your hood?
Thanks!
I hope so, little by little, it will eventually be complete.
As far as the grille, it is a similar material to the lower grilles, but its just much thinner. Its a galvanized metal lath. I had to cut an opening in it to allow access the hood release. I will be finishing off the opening then either applying several coats of paint or sourcing a place to plastic dip. This will add some rigidity to match the look of the lower stock grilles. I may consider putting a stock emblem on, but it will depend on how it looks. The way it is, it looks like a picture on a car wax label, not advertising any automaker. LOL
What can I say, I'm a good listener? Maybe GREAT dane MINDS think alike. It was a commitment, and so far worth the effort. A mild 75 degree afternoon made for some nice pulls today. You've mentioned it in so many posts. Everyone seems to get so caught up in cooling that they have no idea the power that can be gained with getting air in and out without generating so much extra heat, trying to push the air out the cats. Certainly a must for downpipes.
Edit: What did she put up on the dyno or down the 1320' today?
So here are are few pics of the grille. It works great, giving the maximum in space behind it with little to no filter blockage. It also has a finished trim to allow for the hood release. However, it's really not my style or what I care for the car to look like. I will be getting more rigid black flex to help mute things but in the end I don't think it will be on the car for long. In case you anyone is wondering, I wasn't trying to hide anything with the towel, just trying to prevent tiny hardware from falling into hard to reach cavities. PM me an offer if you really want it that bad.
Not quite chicken wire, but thin...stop being a male chicken all the time...lol...I will say I'm thinking of putting another layer of mesh or screen on the inside that may make things less noticeable, thanks for the pic to inspire me.
That makes sense, no trouble matching when its the same material... I'll have to check to see if the lower bumper mesh will be tall enough. Thanks
Touche' good sir.. I was thinking the same add 1-2 more layers possibly rattle can them matte blk
This is a much more rigid 4" diameter flex that I found from Pegasus Auto. Its a neoprene rated for 300 *F which should be fine on this side of the radiator.
I ended up making a 3.75" ovaled ring attached to a flat piece of metal scribed to the same shape as the stock radiator openings. Then I removed the top bolts and used them to hold the flat portion with the opening in place against the plastic of the radiator. With the 4" flex already attached to the oval ring portion, I used high temp silicone to seal and adhere the metal to the plastic/radiator from the inside since the only fastener was the one up top.
I should have taken more pics, but I don't get as much garage time as I'd like. Hopefully the verbal description makes some sense.
There were a few people asking about the silicone elbow sizes I used for my setup so I thought I would update with a list and a picture. I hope that helps. Don't ask for other shots since they are on the car. LOL
Drivers side starting at the turbo:
2.25-2.25 45 deg
2.25-4" straight reducer
4" 90deg
4" 45deg
4" coupling
4" to 3.5" 45 deg
Passenger side starting at the turbo:
2.25-4" 45deg
4" 90deg
4" coupling (to extend straight)
4"-3.75" 45 deg
Dual perpous here folks, if you ever need to house a chicken or 2 overnite? I kid I kid.. Tho someone p-chop this into his grill lol..
