Rebellion TCU Tune
Rebellion has released a TCU tune to reprogram the torque limiters and shifting. The shipped me a little tool that plugs into the ODBII port so nothing has to be removed or sent out. It was literally the easiest mod ive ever done to any car. You have the key in the 2nd "ON" position before starting the car, plug the device in it beeps once, 30 seconds go by and it starts constantly beeping, turn car off & remove, turn engine on and let idle for 5 minutes ... DONE !
Now this car is exactly what I wanted not being held back and able to use that nuke under the hood. Did only about 10 miles of HARD driving so I'm sure it will get even better with more use but very good results ! For races i like to use sport mode with manual selected so it shifts at redline. Stock TCU would give me 5200-5400 rpm in first and ~5800 rpm in second at best... total tease since this car makes power up top. After ripping on it with rebellion TCU it starting going 5800 in first ... 6000 in first, and then finally 2 of last 3 runs it shifted at almost redline in first and complete redline in 2nd. Making use of all the power available and also not bogging after the shifts since the revs dropped to low before with stock TCU short shift.
I also noticed in the cla45 the car would drop boost/ bog after up shifts. I've been in other turbo DCT cars like gtr and they never drop boost in between shifts and feel like one constant gear. I got this feeling now much improved a combination of the higher revs and the faster shifts. Manual mode felt amazing I would bounce rev limiter or short shift with the slow response before but it's more precise now and I was nailing perfect manual shifts. Honestly amazing job guys you've made this car a rocket it's 80 degrees and semi humid it will be mad in the winter at sea level here in nj.
Anyone that owns the CLA/A45 the piggyback is a must.
If you drive the car hard and appreciate performance the TCU is a great addition.
What I noticed is don't use Sport + manual(when your in sport mode and hit the paddles). If you just use sport without manual it nails the upshifts perfectly its almost like when you engage sport with manual it goes back to stock shift points
The biggest difference for me was FULL manual mode(M on screen). The shifts feel MUCH faster and don't bog seems to also have made the snap of upshifts less dramatic. The only thing I was disappointed with was the torque limiters I didn't notice any extra mid range. I was also expecting more of a "violent" reaction when coming onto boost but it still seems to slowly ramp up. The improvements in Full Manual mode and Standard sport mode were great shift wise
A45 with Rebellion ECU and TCU tune running 11.9 with race start.
Agreed.
I think its better than stock....but I was expecting more....especially for the price.
Price wise again is difficult because we have tried to price the S1 very competitively...however there are extra cost associated with the programming tool in the TCU kit that hold it's price up..
I guess the only example I can use is that if you ran our ECU and TCU the total cost is still the same or slightly less than some competitor Stage 1 only kits..
I would also say that the majority of what the TCU kit does will not necessarily be felt as much as seen in results etc.. One of our customers in Spain has put up vbox results in the vid in this thread and these show improvement over S1v2 only in his car..
Maybe we shouldn't have made v2 as good
I just ordered Rebellions gearbox Tune to complete the Ituning that I already have installed so lets see how my car reacts...
unlike Renntech,Eurochagred,Weistec and OE Tuning that you hardly hear from them...keep up the Excellent Job Matt..
The last thing we want is a slanging match between fans or companies, ultimately we are all fans of the same thing... AMG.
I test drove a CLA45 in November of last year and was a bit disappointed by the transmission. When I got my car in April, the transmission felt noticeably better than the one I test drove.
My build date was October 13. If it has the newer version of software, maybe I need to do a tcu reset because of my daily grind?
ML63
You need to go back to school and learn how to read because if you had read then you would of saw that I said the CLA 45 section of this forum and not the C63 section and that's all I have to say on this.....
