CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
Recommended tires
Old May 13, 2015 | 09:54 PM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
Recommended tires
Now that I have all this newfound power in the CLA, close to 100 whp & tq, I'm going to be needing better tires soon to hold the power to the ground. Notwithstanding that I happen to get a wheel sponsor (very unlikely, but you never know), what tires does the forum suggest for holding all that power to the ground so I don't spin like an idiot?
Old May 13, 2015 | 10:03 PM
ddtung's Avatar
Mercedes C200 CGI, CLS350, CLA45 AMG, AMG GTS(ordered)
Michelin Pilot Sport Cup 235/40/18 or 235/35/19 depending on wheel size.
Old May 13, 2015 | 10:08 PM
Treadwear pretty fair on those?
Old May 13, 2015 | 10:34 PM
ddtung's Avatar
Always a tradeoff.
Mine are at 6000 Km and plan to rotate F/R at 8000 Km.
Old May 13, 2015 | 11:52 PM
DONTLIFT's Avatar
CLA45 AMG
Pilot Sport Cup tires recommendation is likely to be a little too extreme.
Check out the Kumho V720's they just came out this year and btw the Cup tires will most likely not be good cold. Btw, the V720 is the OEM tire for the Viper ACR 2016 ... If it's good enough for the fastest car of the year i'm pretty sure it'll be enough for you. Also look to upgrade your rim size to at least a 8.5 width or maybe even a 9 inch wheel if you can get the right offset. I have 8.5 inch wide rims with a +42 offset and it works for me. I also have KW Clubsports which really made the biggest difference overall.
PM me if you want me to get you a quote on some Enkeis. For an 18x8.5 it should end up being around 650 -800.
Old May 14, 2015 | 03:04 AM
I'll keep it in mind though frankly, I like the stock rims, and I'm not terribly interested in spending cash on wheels, heh.
Old May 15, 2015 | 06:57 PM
RedReX's Avatar
'15 MBZ GLA 45 AMG, '15 MBZ E550 Convertible
After I got my tune I went with Super sports, they are cheaper than the stock tires and last pretty long. I went from 235 to 245 and also got an alignment and I noticed a pretty big difference handling wise. you could check out hankook rs3's also. they are a VERY good tire and not expensive at all, not so good in the wet though.
Old May 16, 2015 | 12:56 AM
You can stuff 245s on a CLA? How tall? 245/40?
Old May 16, 2015 | 06:16 AM
SinaFox's Avatar
CLA45 AMG Edition 1
You can run 245/35 R19 PSS on stock 19 wheels no problem. Handling and comfort is much better compared to stock Dunlop's. 245/40 R19 will be too tall. Wheel diameter will change +5%.
PS Michelins are 1% taller compared to stock 235 tires.
Old May 16, 2015 | 06:23 PM
DONTLIFT's Avatar
CLA45 AMG
Super sports are alright but I really don't feel the hype that they're all about. Check out tire racks rebate on the Dunlop direzza z2. Those are solid tires and the width is very wide for a 235 tire, 9 inches tread width.
Old May 17, 2015 | 12:57 AM
I'm running 18's on my CLA 45.
I'm thinking about settling on the 245/40R 18 Continental ExtremeContact DWs. Very solid tire from the reviews, good treadwear and a good price. Only a 4mm change in height. I'm not sold on 245/35 since they're over 8mm shorter.
Rex? What are you running?
