CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
MY20+ Coolant issues
Old Nov 8, 2022 | 06:14 PM
bayareaevo's Avatar
06 cls55
Anyone else have the same issue with their C118 CLA45 with topping off their coolant every few thousand miles? I've been in and out of the dealer regarding this issue. They've performed pressure tests with the cooling system and have not found any leaks. My SA mentioned that AMG's tend to consume coolant more than usual? is that normal lol. This is the only German car i've owned that i had to top off the coolant this often, and the other car i owned was a Honda with a busted head gasket.
Old Nov 8, 2022 | 08:37 PM
crester's Avatar
Merc
I have the same situation. I find myself topping up coolant now and then... not frequently but on my previous cars I didn't have to ever top off. I got told the same thing... that there's no issue... they don't see any leaks and that AMG's just burn coolant sometimes.
If you find an actual problem please let me know because I'd like to know an answer as well.
Old Nov 8, 2022 | 10:04 PM
bayareaevo's Avatar
06 cls55
It’s very frustrating at this point. I’m glad it’s not leaking anywhere but it’s definitely burning off somewhere which is very unusual for such a new car.
Been through 3 different “amg certified” service centers and all of them couldn’t do anymore than a pressure test coz there isn’t any visual proof of coolant leaks around the engine bay other than significant decrease of coolant level in the tank.
does this qualify for a Lemon car???
Old Nov 12, 2022 | 08:50 AM
jacky_li's Avatar
2021 CLA45
I think it’s a common problem of the m139 engine. Just like the bmw engine burn oil. My 2021 cla45 has the same problem too. Lol
Old Nov 15, 2022 | 12:29 PM
Sockinatoaster's Avatar
2023 AMG GT 53
Y'all jinxed me. Here I am thinking I hope this doesn't happen to me. Get in the car this morning, low coolant level warning.
Luckily, after a couple of hours on various MB germany sites I found some locally. Zerex G40 is the MB approved coolant for the M139 engines and is $21 compared to $100+ oem stuff.
Old Nov 15, 2022 | 04:22 PM
crester's Avatar
Merc
I didn't bother getting coolant from the dealer. I just bought Mercedes compatible Prestone Coolant from Canadian Tire and it was fine.
Old Nov 25, 2022 | 02:38 PM
ylli101's Avatar
c63s amg coupe
I had the coolant issue since 2020 when I got mine. I just recently took it in for service and there was a TSB/Recall on the coolant line that need replaced.
Ever since then, no coolant messages!
I would suggest getting that done.
Old Jan 10, 2023 | 03:09 PM
bayareaevo's Avatar
06 cls55
hi, can you kindly scan your work order and message it to me from the dealer or do you know if the TSB/Recall have a reference number? I’d like to show this to my service advisor.
TIA
Old Jan 10, 2023 | 03:15 PM
crester's Avatar
Merc
I would like to see it as well!
Old Jan 11, 2023 | 11:18 PM
bayareaevo's Avatar
06 cls55
Got my car back from the dealer due to a check engine light from a failed part for emissions
also, they also completed 2 campaigns;
Coolant Line
Rear Camera software
surprised the coolant line TSB did not show on the MBUSA.com recall vin database….
Old Jan 11, 2023 | 11:22 PM
crester's Avatar
Merc
Originally Posted by bayareaevo
Got my car back from the dealer due to a check engine light from a failed part for emissions  also, they also completed 2 campaigns; Coolant LineRear Camera software surprised the coolant line TSB did not show on the MBUSA.com recall vin database….
Technical Service Bulletins are not recalls. That's more of... if an owner has a problem... this is how you fix it.
Old Jan 12, 2023 | 12:05 AM
bayareaevo's Avatar
06 cls55
I’ve always thought they’re the same
