Carlsson C Tronic ECU Upgrade from GMP Performance
Do you want an increase of smooth and reliable power?
Do you want to be able to install it and go back to stock in minutes?
The Carlsson C Tronic ECU upgrade is the answer.
http://www.gmpperformance.com/index....arge&IMG=31648
As you can see from the picture it installs as exactly as it appears in the picture. Simply remove the vehicles harnesses from the ECU, install the C Tronic Upgrade to the ECU and reconnect the harnesses to the C Tronic Upgrade and your done.
Carlsson claims that 253hp and 309 ft lbs of torque are capable through this upgrade.
Here's a little bit of information also from their website which is also very important and good to know.
"To protect the motor from undue stress, the module is programmed to only make its extra performance available when the oil temperature reaches 50 degrees Celsius. It also disengages as soon as it senses any engine safety related parameter reaching the factory ECU’s limits."
We are now taking pre orders with units expected to arrive in the next couple of weeks.
We are doing 10% off on the first 5 orders. To get this deal you would need to call me directly @ 704 525 0941 EXT 257.
http://gmpperformance.com/index.cfm?...ID=318576&VS=1
Michael GMP Performance Michael@gmpperformance.com 704-525-4946 x257
