A-Class (W168, W169) A140, A160, A160 CDI, A170 CDI, A190, A210 Evo, A180
W168 A160 No gear indicator cannot start ?
Old Jun 7, 2010 | 12:30 AM
hellgrace5's Avatar
CLK320
I have a W168 A160 which cannot start.
My dashboard doesnt show any sign of P,R,N,D could it be the gear selector module fault ?
Old Jun 15, 2010 | 04:01 PM
Hubi's Avatar
S550, E320 Sport Wagon and A170CDI :)
do you have F instead?
Old Jun 15, 2010 | 06:06 PM
hellgrace5's Avatar
CLK320
There is no F indicator too
Old Jun 4, 2011 | 02:40 PM
habo's Avatar
A 160
My name is Habo, My wife's 2003 A 160 doesn't show gear indicator and show BAS/ESP and
it won't charge gears
Old Jun 4, 2011 | 03:09 PM
habo's Avatar
A 160
please reply
Old Jun 8, 2011 | 03:10 AM
hellgrace5's Avatar
CLK320
Hi
Did u recently replace/remove your battery ?
Did u scan it with a scanner and showing any codes ?
Try turn your steering full from left to right and right to left and then center and restart your car see if the BAS/ESP is gone.
For not showing gear indicator it may be the gear selector switch or the auto trans.
I change both to make sure everything goes ok. Does your auto trans working good before ? if yes try just change the gear selector switch 1st.
Just my 2 cents
Old Aug 15, 2011 | 12:29 AM
Jane1234's Avatar
A160
F on Dash car won't start
HI All,
I have a similar problem my A160 will not start first thing in the morning by 10am it is OK and starts fine. I have been told it is the ECU which I have had replaced and the tranmission yet it drive's great, I have also been told it is the battery. When it does not start there is an F on the dash. Any idea???
It can't be all three it has to be one or the other
Old Dec 23, 2012 | 04:39 PM
kee's Avatar
kee
mercedes A160 auto
Hi All, Broken A160 auto gearbox ECU. Anybody know where I can repair/replace/purchase used auto gearbox ECU in S.A? Car in limp mode. 2001 model. Thanks.
