A-Class (W177) (V177) 2018 to present
A250e Plugin Hybrid 2020
Old Apr 15, 2020 | 03:45 PM
Tonde1's Avatar
MB EQA 250
Today got my new A250e plugin hybrid and first experince feels very good.
100% full charge estimated 82km (51 miles) and finally drove 68km (42 miles) full electric.
Outside temp was +5C.
Made a short video of charging operation:
Old Apr 16, 2020 | 01:04 PM
Tonde1's Avatar
MB EQA 250
Also tried first time public charging station and it worked very well too, it gave 5,5kW.
Made also short video of it using Type2 adapter:
Old Apr 17, 2020 | 09:52 AM
Tonde1's Avatar
MB EQA 250
A250e plugin hybrid gives quite low consumption figures, today drove 175km (109miles) with 0,0l/100km (0,0mpg) gasoline, electric 16,5kWh/100km.
MB A250e plugin hybrid consumption, 0,0l/100km, 16,5kWh/100km.
Old Apr 17, 2020 | 04:51 PM
Vampire1984PL's Avatar
MB W177 A250 4Matic
How long do You charge? Hows gearbox? How responsive it is? How with acceleration in Your opinion is?
Old Apr 18, 2020 | 10:12 AM
Tonde1's Avatar
MB EQA 250
Charging at home using 1-phase schuko takes about 7hours (mercedes portable charger gives only 8A, 1,7kW rate). Public charging with 7,3kW takes about 2hours 0-100% full.
Acceleration is quite ok in full electric mode, it’s not a rocket, but enough for daily electric driving.
Just recorded 0-100kmh (0-62mph) using Full Electric mode. You can even hear electric motor and gear changes I haven’t been using gasoline engine at all, so far all driving full 100% electric, so dont’ know yet about this 8-speed DCT if gasoline engine is used.
Here is the video of Full Electric acceleration:
Old Apr 18, 2020 | 03:30 PM
MB W177 A250 4Matic
This looks very good and promising for only Electric Mode. Best in city
Can I have request to You to record petrol engine with electric acceleration ? Im asking because many reviewrs didnt like this 1.33 engine noise, wonder if it is still in A250e noisy
This above 175km that You drove was used 72% of battery, right? ( i can see 28% left on right bottom and 16 km left )
7hs to full charge is not so long and enough. The best is that You can drive more than 150km on EM and rest on petrol...wonder for how long can You drive on petrol on motorway driving legally
Old Apr 18, 2020 | 03:55 PM
Tonde1's Avatar
MB EQA 250
Let’s see, I may do it, you are not the first one to ask petrol engine + electric acceleration video
That 175km full electric trip required 2 public charging station visits, both 7,3kW charge rate. When started on the morning, car was in 100% full charge.
Navigation helped a lot to estimate available electric kilometers compared to distance to next public charging point. Both stops showed only 2kms electric left, so went quite close
This car really has potential for daily electric driving, you can get 60-70 electric kms quite easily.
I haven’t yet tried towing how it affects to electric kms.
Old Apr 19, 2020 | 08:21 AM
MB W177 A250 4Matic
60-70 is not a lot to be honest but to be fair, it got petrol engine . This EM is just ideal for city cruising .
Wonder how much does it recharge when driving on petrol and on normal roads outside city
Old Apr 19, 2020 | 10:22 AM
Tonde1's Avatar
MB EQA 250
Did that test, many viewers requested it, so here it comes, acceleration using petrol engine and electric = Sport+Electric -mode:
Old Apr 20, 2020 | 11:15 AM
MB W177 A250 4Matic
Wow so fast...7s very very nice
Old Apr 21, 2020 | 10:44 AM
Tonde1's Avatar
MB EQA 250
Tried also MB A250e voice assistant and it knows a lot of more than just navigation. It seems to understand even non-native English speaking person pretty well.
Old Apr 21, 2020 | 02:10 PM
MB W177 A250 4Matic
Yeah its awesome
Ask him what she thinks about Audi or BMW
Old Apr 23, 2020 | 10:51 AM
Tonde1's Avatar
MB EQA 250
Viewers asked to test acceleration full electric with 100% battery charge. There is indeed a performace improvement if its full or 12% charge left (13,9s).
Here is the test run with 100% full battery charge, 0-100kmh in 12,5s:
Old Apr 25, 2020 | 11:51 AM
Tonde1's Avatar
MB EQA 250
A250e plugin hybrid towing capacity is 750kg / 1600kg, created a short video how partly electronic towing hitch works:
Old Apr 28, 2020 | 10:52 AM
Tonde1's Avatar
MB EQA 250
Now tried more powerfull 22kW charger, A250e can charge with it’s max 7,4kW rate which is much more faster than schuko portable charger.
Old May 1, 2020 | 09:46 AM
Tonde1's Avatar
MB EQA 250
Somebody asked how pre-Airconditioning / Heating works if car is plugged-off.
Created video how-to-set-up pre-heating using MercedesMe mobile app, there was -5,5c outside on the early morning for this test and cabin was warm +19c.
Old May 5, 2020 | 09:33 AM
Tonde1's Avatar
MB EQA 250
Created A250e Exterior video including engine compartment, fuel tank door opening, charging door. Fuel tank door takes about 5secs to open because there is pressure valve and driver needs to wait pressure balance.
Old May 12, 2020 | 09:31 AM
Tonde1's Avatar
MB EQA 250
Also different Themes can be selected on displays:
Old May 20, 2020 | 10:29 AM
Tonde1's Avatar
MB EQA 250
A250e Luggage space is flat, rear seat can be split 40:20:40, just recorded video:
Old Jun 2, 2020 | 09:34 AM
Tonde1's Avatar
MB EQA 250
Quite good electric range getting in Merceded A250e Plugin Hybrid, 100% full charge and 75km electric range (estimated):
Old Jun 9, 2020 | 03:00 AM
Irondan11's Avatar
Skoda
Petrol mode
https://youtu.be/3te5YqtLaq0
How is the acceleration in all petrol mode. I know its the same 1.3 litre engine as some of the normal a class, but wanted to see how it coped with the extra weight?
Old Jun 9, 2020 | 03:16 AM
Tonde1's Avatar
MB EQA 250
It’s faster in petrol mode, I got 0-100kmh 6,4s, ESP Off in Sport mode even battery was completely empty (1%, 0km electric range):
Old Jun 9, 2020 | 03:24 AM
Irondan11's Avatar
Skoda
https://youtu.be/hzqBo_9gFYw
How is that possible? A regular a200 1.3 litre amg line (the same engine) does 0-100 kmh in 8 seconds? So if you are only in petrol mode in the hybrid which has significantly more weight then it will be slower than that. I think your video is showing the acceleration of hybrid plus electric. Could you take a look please?
Old Jun 9, 2020 | 03:56 AM
Tonde1's Avatar
MB EQA 250
Yes, A250e will keep always 1-2% charge and will be still able to use electric boost even electric range is 0km and electric mode cannot be selected in driving menu. This is visible ex. when leaving stop lights, car can be driven some ten meters pure electric even range is 0km and electric mode is disabled in the menu.
Old Jun 26, 2020 | 03:29 PM
Tonde1's Avatar
MB EQA 250
Tested A250e Plugin Hybrid Automatic Self-Parking, works amazingly well:
