A-Class (W177) (V177) 2018 to present
Centre display screen all lines
Old May 26, 2025 | 01:48 PM
Jakd's Avatar
A160 AMG
The centre didplay screen between the clocks has developed a fault and shows lines 2/3 of the way up the screen. This the display that gives general car info - milage etc. Top part still working.
Did not get a bang or anything, was just like that after I returned from holidays. Like that a month+ now.
Has anyone similar experience... does it cost much to replace.
Thanks in advance for any advice.
Lines up centre of display
Old May 26, 2025 | 03:40 PM
W205C43PFL's Avatar
You sure the connection isn't just loose or something for some reason?
Old May 26, 2025 | 05:19 PM
Jakd's Avatar
A160 AMG
I not sure how to check. I had just parked it and all fine. When I returned it was like this when I turned it on
Old May 26, 2025 | 06:34 PM
W205C43PFL's Avatar
I am hoping it is a loose connector instead of internal stress/fatigue crack/thermal stress. Check the screen carefully and see if the LCD inside is cracked. As for checking, the only way is to remove the dash so not ideal.
Old May 26, 2025 | 06:35 PM
W205C43PFL's Avatar
Correction: as for checking if its is a loose wire, the only way is to remove the dash.
Old May 27, 2025 | 02:35 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W177 forum...
Old May 29, 2025 | 09:36 AM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
It might be a trip to the dealer. Not sure if you can replace the screen without coding.
You mentioned you just returned from holidays, was it an extended period (IE. couple weeks). Possibly a weak battery or low voltage may have attributed to the issue.
Old May 29, 2025 | 10:05 AM
W205C43PFL's Avatar
Some possible causes yes, worth checking.
