CLE COUPE 2023
I am interested to know if anyone of you have information about this new model - CLE Coupe- that is expected to become the replacement of the C- Class and E- Class Coupes for the next year.
Specifically the AMG series.
Thanks a lot
Eltigre
I wouldn't consider myself an expert at all as many others are much more (I mean much more) knowledgeable than me but let me try to answer your questions to the best of my knowledge in detail : ).
The CLE is based on the same platform (MRAII) the W206 uses, so it is possible that it will use the same engine lineup as the W206. As far as what we seen so far, the next E-Class will at least have an inline 6 available so if the "E" in the "CLE" is dominant, then it may use the E-Class' lineup of engines. Dominant for example the SLC, the "C" was dominant and it was basically a C-Class based roadster. The W214 E-Class will be based on the MRAII platform as well.
An inline 6 can actually fit in vehicles based on that platform (MRAII), the reason I know is because the X254 (basically the 2023 GLC) will have a inline 6 diesel for Europe although no AMG versions of the X254 will have a six cylinder and that is pretty much confirmed, the W223 (S-Class) based on the same platform (MRAII) has a V8 and even V12 in the Maybach version so it is possible to make it fit if Mercedes wants to. So there is still possible hope for six cylinders for the CLE. It is possible that Mercedes wants to reference the CLK and its position in MB's lineup on top of the merging of the C and E Coupe/convertibles, creating this CLE.
For your other question, if you only want straight line performance and sound, the BMW will win for sure and you will feel right at home since you currently have one. As the BMW you mentioned to compare with the C 43, it has the inline 6 with a 48V mild hybrid system (I think?), did you consider the new M3 as well? While the W206 C 43 has the M139l inline-4 from the R232 SL 43 also with the 48V mild-hybrid system and e-turbo from Mercedes' Formula 1 team but the W206 C 43 is heavy, the four cylinder wouldn't sound as nice as the BMW. Here is a W206 C 43 sound clip recorded by a reviewer (youtube.com/watch?v=FsOSJwSGVUE). There are also things to get used to coming to Mercedes-Benz but it is probably worth it and exciting for you to learn new things : ) (at least in my opinion) You may also consider the W206 C 63s e performance as well if you don't mind the weight of that thing, it has the same engine and turbo but it is plug-in hybrid and has electric motors with much more horsepower, the base horsepower of the engine is higher than the W206 C 43 too.
It also depends on how long you want to wait and if you are in a rush for a new vehicle (if you are indeed in a rush I would actually recommend getting that BMW so you can enjoy first and you can always hop on the CLE later. Since you are considering the CLE though, you wanted a coupe or convertible? If so then you might be looking at the four series, or you want a roadster, the Z4, as far as I heard, it was recently facelifted but with minor changes.
I am wondering if you will miss the V8 from your vehicle, your other options could even be the current gen C205 C 63s, with the M177 4.0L turbocharged V8 unless you need 4MATIC? If V8 isn't a must have and you need 4MATIC, you could also consider the C205 C 43 4MATIC as well as it has a M276 BiTURBO 3.0L V6 and it sounds good too (but I am biased). I am also not sure how long you keep your cars for because the engine in the C 43 is proven to be reliable and there is no mild-hybrid things that has a risk of failing.
The CLE isn't revealed yet and being a (relatively) low priority vehicle, it will take a while before it arrives to South and North America, and the chip shortage isn't helping, although thankfully it seems like the chip shortage is slightly better than before. Since from your previous message, you stated you were interested in the CLE 53 (if it follows the W214 E-Class line-up) or CLE 43 (if it follows the W206 C-Class line-up) the wait will be longer, probably at least a couple of months to half a year. As MB will likely reveal the regular Mercedes-Benz models first which as you know that also isn't revealed yet. Which means the CLE 43 or 53 might be a 2024 model year vehicle, there is still hope for 2023 model year though. Another thing is, there were times that Mercedes does use the 43 and 53 nomenclature in the same class as well, for example the EQE class with the EQE 43 and EQE 53.
As for your other question on how the CLE looks like, here are some images posted online: https://www.motor1.com/news/615630/m...rst-spy-shots/
If you like the interior and exterior design of the W206 C 43, that might be enough of a reason why you want that car. I am not sure about South America but as far as I heard, North America is going to start getting shipments of first batches of W206 C 43 by the end of this year from productions that commenced in late September to early October. I am also not sure how long the wait is to actually submitting an order to the dealership and then building it though, you might want to ask your dealership about that as it is region dependent, sorry about that : (
Hope that helps : ) Please feel free to reply with further questions, I will try my best to answer them if I am able to.
Thank you so much for your extensive response .I will be alert when the official MB world premiere of the new CLE will be .
This is the kind of car I've been dreaming of for sometime,and the ideal replacement of the M3 E92 I own .
if they are slow they basically just give revenues to BMW and AUDI
I hope at least it gets E-class colors
Prices will be interesting because of that. Obviously it can't be more expensive than the W214 E-Class.
reading the cylinder head stories on GLB and GLC forum makes me scary
