CLE Class Coupe (C236) & Cabrio (A236) 2023-
Tire Pressure measurement query
Old Nov 30, 2025 | 12:31 PM
dudley07726's Avatar
2023 BMW M340i, 2025 MB CLE53 AMG
I asked Hey Mercedes to tell me the tire pressure and it read it out in kg instead of pounds. How do I change it?
Old Nov 30, 2025 | 01:16 PM
HoustonCLE53's Avatar
2025 CLE 53
According to this, it should be picked up from the settings in your car...have you verified those settings are correct ?
To switch the units for the "Hey Mercedes" voice response (and other MBUX displays), you will need to adjust the settings in the multimedia system manually
. The voice assistant pulls information from the vehicle's set display units.
Steps to Change Display Units
  1. Go to the Home screen on your MBUX infotainment display.
  2. Scroll across to the "Settings" page or icon.
  3. Select "System".
  4. Scroll down and select "Display" or "Display messages". The exact menu names may vary slightly by model year and software version.
  5. Look for "Units" in the display settings menu.
  6. Select the desired unit (e.g., kilometers or miles, Fahrenheit or Celsius, kPa or bar/psi for tire pressure) depending on what specific response you are trying to change.
  7. The system should immediately change the display and voice responses to the newly selected units.
Old Nov 30, 2025 | 01:35 PM
Hi thanks.
when I go to units, I only see miles or kilometers. Nothing for temperature.
Old Nov 30, 2025 | 06:11 PM
Rocketman1980's Avatar
2025 CLE AMG 53 Coupe
I also noticed that the mountain heights shown on the navigation route are in meters not feet. My settings are correct for USA but nav won’t indicate correctly.
Old Nov 30, 2025 | 06:30 PM
superswiss's Avatar
2019 C63CS
Mercedes doesn't allow you to adjust any units other than distance. The units for pressure and temperature are predetermined by the car's region. So for the USA the pressures should be in psi and temperatures in Fahrenheit. Some of the third-party coders have claimed that they can change it. Pressure in kg anything isn't used anywhere. Europe and much of the rest of the world uses kPa or bar. kg per square centimeter is a deprecated unit of measure and I've never seen it used anywhere. What exactly is it readying out? Pressure in kg isn't a correct unit. Is it reading them out in kg per square inch, or what exactly is it saying? When you bring up the tire pressure on the display, what unit are they in? As said, in the USA it should be psi. Sounds like this is another one of the wonderful bugs that have enriched MBUX since its debut.
Old Dec 1, 2025 | 08:35 AM
Yes, the voice is reading the pressure out in kPa. The readout if I keep scrolling under service (on the steering wheel) is in PSI. Very strange. It's much easier to ask Hey Mercedes what the tire pressure is rather than scrolling. I am able to ask in my BMW and it reads it out in psi.
Old Dec 1, 2025 | 11:58 AM
superswiss's Avatar
2019 C63CS
Sounds like a bug then. Somebody forgot to make Hey Mercedes properly aware of the car's region, or possibly something got miscoded in your car at the factory. Maybe somebody else can try it to see if they get the same. Just out of curiosity, if you explicitly ask Hey Mercedes to give you the pressures in psi, is it capable of converting them on the fly? FWIW, I generally have the pressures up in my instrument cluster at all times. In my '19 C63 there's a performance display that shows all the temps and the tire pressures. I primarily keep an eye on the temperatures, so I can judge the grip of the tires and know when the engine and transmission are warmed up. I don't remember from the top of my head if there's a similar display that you can bring up in the newer instrument clusters. They are less customizable than before.
Old Dec 1, 2025 | 12:24 PM
It was not capable converting it to psi.
Old Dec 16, 2025 | 02:17 AM
gotenks1859's Avatar
Just wanted to chime in here that i am facing the same issue with my glc 350e. Oddly enough this happen after my car successfully upgraded to mBux 3.3 couple weeks back. Prior to the software update, I happened to get a low tire pressure light during my drive and I asked "hey mercedes" repeatedly what my tire pressure was. Each time, answer was in PSI.
Now after the update, when i asked for tire pressure, it is read in kpa only. I checked and confirmed my units in display only show ft and/or miles but no tire pressure setting. In my dash for service view, it lists my tire pressure in psi.
I've been trying to find others who may have noticed this same issue happening and this is the only post ive seen acknowledging this issue. I am based in California so it makes no sense why my units changed but only when i asked via hey mercedes
Old Dec 16, 2025 | 07:40 PM
BenzC400's Avatar
AMG CLE 53
The Mercedes App, unit section, of your profile allows you to select kPa, bar, or PSI for tire pressures. I don’t know if that will change the Hey Mercedes read out though. I haven’t tried it yet.
Old Dec 16, 2025 | 08:18 PM
I went into the app but did not see where to change the measurements.
Old Dec 16, 2025 | 08:22 PM
superswiss's Avatar
2019 C63CS
Tap on the profile icon in the upper right corner, then Settings|Units, but those only apply to the app itself in my experience. For example I have temperatures set to Celsius in the app, but the car still shows Fahrenheit. So these settings do not apply to the car.
Old Dec 16, 2025 | 08:42 PM
BenzC400's Avatar
AMG CLE 53
Make sure your MBUX in the car is set to sync your profile automatically or try syncing manually.
Old Dec 16, 2025 | 08:44 PM
superswiss's Avatar
2019 C63CS
Make sure your MBUX in the car is set to sync the profile automatically or try syncing manually.
Makes no difference. These app settings are not part of the profile that's synced to the car.
Old Dec 16, 2025 | 09:29 PM
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
Must be a bug. I'm in the same boat with my W214 E450 Wagon in the U.S. Prior to the 333 update I would use Hey Mercedes to check tire pressures and it would answer in psi. After the update it's been answering in kPa. On the service screen it reports in psi. The setting in the Mercedes app says psi. When I use Hey Mercedes and specifically ask for tire pressures in psi, it still responds with kPa. There's no place in the car's Settings menu that references tire pressure units - just Kilometers v. Miles and Fº v. Cº.
Looks like we will have to wait it out. I won't go to the dealer for it, but if I'm in for something else I'll mention it. I'm sure they'll look at me like I have 3 heads.
Old Dec 17, 2025 | 08:05 AM
nope, shows in psi but system states it in kpa.
Old Dec 17, 2025 | 04:43 PM
I agree it does appear to be a bug as everything you wrote above on your E450 is exactly verbatim to the same issue i've seen in my glc 350e. I did also check my mercedes app to confirm it says psi and it never changed. But just to test it out further, i even selected kpa in the app and let it save, then go back to psi and save. But hey mercedes doesn't seem to register that point and still say kPa.
This is my first mercedes and first mbux update...do they push out like a bug fix software update like a mbux 3.3.1 or something? Or we have to wait until mbux 3.4?
Old Jan 27, 2026 | 01:41 PM
pomko's Avatar
2025 E450
2025 E450.
Same problem.
Hey Mercedes gave it in psi until a software update.
Now in kPa.
I'm in Toronto and dealer can't find the problem.
Old Jan 29, 2026 | 03:07 PM
mjastuart's Avatar
2025 GLC 300
Noticed the same thing in my 2025 GLC after the software update with no joy in finding a way to reset it. I'll bring it up when I'm next at the dealer. BTW, I was impressed when (as I was driving) I asked "Hey Mercedes" to convert 240 kilopascals to psi and it gave me the correct answer.
Old Mar 10, 2026 | 03:50 PM
J.Raymond's Avatar
'08 BMW 335i Coupe '15 E400 Sedan '25 CLE 53 Coupe
Same problem with CLE53 after installing 3.3 - tire pressure audio report now in kPa. Regularly use this feature - will explore a fix.
Old Mar 19, 2026 | 12:23 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Just remember 30 psi is 206 kpa, 35 psi is 241 kpa. Divide kpa by 6.9 to get approximate psi.
Old Mar 21, 2026 | 08:58 AM
Take out a calculator. Just what I feel like doing when I asking for the tire pressure.
Old May 10, 2026 | 09:27 AM
mjastuart's Avatar
2025 GLC 300
Took my GLC 300 in for Service A last week and asked about the tire pressure audio reporting. It is a known issue and there is currently no interface that allows this setting to be changed. I anticipate MB will either add such an interface or - more likely - flip this setting to PSI for US spec cars in the next update that touches the code that includes this setting.
Old May 11, 2026 | 07:33 AM
W205C43PFL's Avatar
Originally Posted by pomko
2025 E450.
Same problem.
Now in kPa.
2026 E 350 in Toronto, Canada. Same issue will either use the forum members' recommendations of converting or just using the phone app to check tire pressures for now.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
