Rubbing In Front Tire
Old Mar 11, 2005 | 01:29 PM
gate1way2's Avatar
W220, W208, W203
Hey guys quick question i mounted my 235/35/19's yesterday to my 19 x 8.5 on my clk they are offset is 35, when i mounted them the installer said they were hitting with an upper metal in there that has a big bolt, i'm not sure what it is but i'll try to take a picture. Has anybody every experienced this? Does anybody know what this is? There is the spring, shock and then some big piece of metal coming out that connects to the brakes? Can this be removed or do i need to go with a with less wider wheel?
David
Old Mar 11, 2005 | 01:38 PM
x15jq's Avatar
I had the same problem that is ur upper ball joint. I shaved the bolt head down till it didnt rub, my car has been like this for 2 yrs everything is OK!
Old Mar 11, 2005 | 02:37 PM
mtimmy's Avatar
W208 55 & R170 230
235 35 19 is obviously not the correct size.,!!!!
.... you should use 235 30 19
Old Mar 11, 2005 | 05:03 PM
gate1way2's Avatar
W220, W208, W203
i used the 235/35/19 because that's what everyone recommended, forum members, tire shops, etc
Old Mar 11, 2005 | 05:26 PM
x15jq's Avatar
Ive never seen any shop put a 30 sidewall on the front of a benz. Thats way to think, and you need some sidewall to actually have the rims last more than a week.
Old Mar 11, 2005 | 05:56 PM
tampa CLK's Avatar
99 CLK RENNtech Coupe
I am running 235-35-19 on mine with no rubbing at all. That size is also the closest to OE as to not mess with the ABS or ASR.
Old Mar 11, 2005 | 08:28 PM
mtimmy's Avatar
W208 55 & R170 230
ops my bad., I was thinking 235 30 20,.
yeah... 235 35 19 is correct.,., ...
