wheel spacers and bolts
Old Mar 7, 2005 | 10:03 AM
lz_clk's Avatar
1999 CLK 320
Anybody know where I can get some high quality wheel spacers and bolts online? I was thinking H&R, 10mm. Thanks in advance.
Old Mar 7, 2005 | 10:16 AM
smalldog's Avatar
clk
I justed ordered a 10mm set from these guys. Cheaper then h&r they fit/work great.
http://www.bekkers.com/Merchant2/mer...ry_Code=bmrims
Old Mar 9, 2005 | 05:45 PM
mtimmy's Avatar
W208 55 & R170 230
If I am you., I will not use any thing other than H&R for spacer.,
The spacer needed to be very balance and hubcentric. for your can to run smooth and SAFE
the extra 30 dollars for H&R is well worth it
Old Mar 9, 2005 | 06:12 PM
smalldog's Avatar
clk
Its whatever works for you. The ones I got from bekker works great for me.
Old Mar 9, 2005 | 07:10 PM
CLKBSVegas's Avatar
a Black
carefull with 10mm up front. I got a wobble!
Old Mar 9, 2005 | 07:22 PM
smalldog's Avatar
clk
I only added the 10mm to the rear. My wheels are 19X8.5 with a 38mm offset. They are hubcentric also.
Old Mar 9, 2005 | 07:45 PM
mtimmy's Avatar
W208 55 & R170 230
if you get 35 to 38 up front you don't have to add spacer...
plus its not recommanded to add any thing more than 5 mm in front.
smalldog: show some new photos please.
here you go with my
Old Mar 9, 2005 | 07:48 PM
mtimmy's Avatar
W208 55 & R170 230
here u go.
Old Mar 9, 2005 | 09:03 PM
smalldog's Avatar
clk
I will post some close-up pics tomorrow.
Old Mar 9, 2005 | 09:22 PM
mcmaster's Avatar
2002 CLK 430
what
what kind of rims are those... size???
thx
Old Mar 9, 2005 | 11:46 PM
mtimmy's Avatar
W208 55 & R170 230
19X9.5 rear 19X8.5 front. 3 inch lip
Old Mar 10, 2005 | 12:19 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
here you go with my
I would have to say your statement is to general to be true. For instance, ET35 to ET38 up front doesn't work for me with an 8.5" wide rim and a 245 wide tire. I have to use ET30.
-s-
Old Mar 10, 2005 | 01:37 PM
PUREMS's Avatar
H&R does not recommend spacers > 5mm on the front of these models. The front hub is abnormally long compared to the rear. As a result using 10mm+ spacers on the front will result in the spacer not sitting flat against the brake rotor.
10mm+ spacers have an additional mounting lip to them, where you would normall rest the wheel onto. This extra lip will make contact with the hub before the spacer can sit flat against the rotor. This is only an issue with 10+mm spacers, on the front hub.
Old Mar 10, 2005 | 01:54 PM
smalldog's Avatar
clk
here are some pics
Attached Thumbnails wheel spacers and bolts-williammercedez1.jpg   wheel spacers and bolts-williammercedez2.jpg   wheel spacers and bolts-williammercedez3.jpg   wheel spacers and bolts-williammercedez4.jpg
Old Mar 10, 2005 | 08:05 PM
lz_clk's Avatar
1999 CLK 320
Yeah, I was only going to add them to the rear. I didn't know alot about the wheels before I got them, so I got 8.5" all around. I think i"m gonna get the 10mm for the rears and try to be like smalldog
Old Mar 10, 2005 | 08:57 PM
smalldog's Avatar
clk
Same with me......When I got my wheels I was thinking about rotating them. With the spacers I kinda got best of both worlds.......
Old Mar 11, 2005 | 08:34 PM
mtimmy's Avatar
W208 55 & R170 230
true not very General., statment.,
because not a lot of people use 245 in front...
but for a ET30mm ... your rim is already sticking out from the fender wall..
make it look like the mexican pick up with big spacers.
Btw. adding 10MM to the rear helps handleing a lot !!!!..
Old Mar 11, 2005 | 08:50 PM
scorchie's Avatar
I don't think my car looks like a pick up with big spacers... and most people agree.
However, ET35 to ET30 is ONLY 5mm difference. 5mm is enough to clear the ball joint bolt. I'm not sure how you think a mouse pad's thickness is going to make the tire stick out that far.
-s-
Old Mar 11, 2005 | 09:06 PM
mtimmy's Avatar
W208 55 & R170 230
I am not saying your car is !! ... dont' get me wrong...
how much did you lower your car btw?
Old Mar 11, 2005 | 09:14 PM
scorchie's Avatar
Hahaha! You WERE saying it is like a pickup truck, huh? j/k
Mine is lowered on H&R with the original #2 pads, which makes it pretty low. I was looking for a picture to demonstrate that the front tires don't stick out, but I can't find one now.
About as low as yours, except it is on 18s right now.
-s-
