H&R springs and Bilstein Shocks
1. Does anyone have any exprience with the Bilstein/H&R combination?
2. Would it rub or change the ride quality for the worst?
3. Does it cause any other issues like tougher steering, etc?
4. Do I really need to change the shocks as well? Would just the lower spring not be enough? What would I gain/lose if I do change shocks as well?
5. Does anyone see any issues buying these used?
Thanks very much in advance.
yes, i've had them on my '91 300E. same combo and it handles better than my stock clk430. i think it outhandles A LOTTTTTT of cars... i can powerslide/drift turns with no problems in the rain and in dry weather, i can grip corners pretty well even without a thicker sway bar. the bilstein/hR combo is known to be the most favorable suspension setup for a mercedes
depending on the rims and what shimmy pad you are going to run. if you have 18" wheels and are on #2 pads... no problem at all... with #1 pads.. i wouldn't be too sure.
probably very mild if any
since u have both.. might as well change them at the same time. if your car is over 50k... it's good to change shocks since the older ones may be a little worn and won't absorb impact as well as they use to. if you swap your stock shocks with bilstein sport... you will have a stiffer ride esp. with the sport springs... meaning you will be more flat on corners and overall better handling. you will feel a bit of a more "bumpier" ride but it's well worth it i hear.
some dealers are shady... just try to find out how long they've been on the previous car and use "poker instincts" to see if they're lying or not :p
I have got about 22K on my car, so that's why I wan a bit unsure about changing the shocks. I also have the stock 17" AMG wheels on the car. What are these shimmy pads you are talking about? The dealer has told me that I can have a "spacer" that would allow me to choose how much I want to lower it by....and I am not really sure if I should go for the full 1.5" or not...any ideas/
the au****?!
omg
take pix and let us know what size pad's you're using.
