Steering vibration
Old 04-09-2005, 08:54 PM
yuanja888's Avatar
Steering vibration
Recently my car started to vibrate like the wheels are out of balance. It gets worse as u pick up the speed. It starts off small at 60 mph and gets more intense at 70mph.
So I took the car to the wheelworks that did my tires and asked them to redo the alignment and balance. Then while i was at work they called and told me that steering linkage tie bar is loose. They replaced something and fixed it. The guy said that he has did a few clk that had the same problem.
Have anyone had similar problem?
Old 04-09-2005, 11:02 PM
EuCLK200's Avatar
I know some posts on other mercedes forum where more than 10 persons had this problem including me...
There are several possibilities for this.
I`ll list them below in the highest posibility order:
1. tires, replace them
2. aligment and all other wheels setup stuff`s
3. steering tie bar
4. rotors
Most people solved the problem just by replacing the tires.
I had the problem coming from one of the front rotors, i changed them and solved it out.
Make sure you find out what the exact problem is before changing all the direction pieces
i`ve done all the 4 points and finally solved the problem by replacing the rotors in the end of course
Old 04-10-2005, 01:24 AM
yuanja888's Avatar
My case was the tie rod. the tires were newly installed and balanced. I just can't understand how MB's design is so weak.
It seems a number of ppl stopped by the shop to get it done too. The service guy told he fixed a few of them.
Old 04-11-2005, 12:04 AM
smalldog's Avatar
clk
How much did he charge you? I'm having the same problem....i had my wheels reblanced twice. Where is the steering tie rod located?
Old 04-11-2005, 12:13 AM
E55AMG99's Avatar
1951 Caterpiller D6
Add bent rims to the list of possible vibration causes. Somehow I bent both right side stock 17" AMG wheels on my CLK. The wobble/vibration got worse with speed.
Old 04-11-2005, 12:30 AM
smalldog's Avatar
clk
When you balance the wheels the shop should be able to tell if the wheels are bent or not.
Old 04-11-2005, 02:07 AM
yuanja888's Avatar
The shop charged me $280 for parts and labor.
Old 04-11-2005, 02:40 AM
x15jq's Avatar
Thats a good price for the tie rod. Its a one piece unit called the drag link. It includes the center steering link and 2 tie rods plus ends. It is all one piece. THe piece retails about 160, if you got 280 with labor id say you got a good deal.
Oh yeah, the 17 inch amg's are notoriously weak. I have bent 3 so far. Sometimes if the bend is not bad enough, you can balance it out. I would never buy those rims from the mb dealer tho unless i wanted to spend a chunk of money
Tire out of round is a common problem, but that would be discovered with wheel balance. The belts sometimes shift, and it wobbles making your steering wheel shake.
Old 04-11-2005, 09:59 AM
E55AMG99's Avatar
1951 Caterpiller D6
I upgraded to 18" from an SL when I bent the 17". Good point about the bad tire. Had one of those on the E55. Always pulled to the right even though alignment was perfect.
Old 05-03-2005, 01:53 AM
smalldog's Avatar
clk
I had my tie rod checked today. It turned out to be ok. The steering wheel vibrates around 60mph sometimes and other times it rides smooth? Could I be overlooking something.....
Old 05-03-2005, 12:25 PM
yuanja888's Avatar
The guys that replaced the tie rod also told me that when the car is parked for a while, the tires especially ones like mine (sp9000) tends to deform. After driving it a mile or so it will be completely round again. So one would feel the vibration on high way then after a mile (warmed up) the vibration would be gone.
Old 05-03-2005, 12:57 PM
lowphat's Avatar
00 KLEEMANN CLK 430 - 02 KLEEMANN CLK55 - 88 Euro / Jap AMG 560 SEC Widebody
Get this - last weekend it rained here - I'm on the highway and accelerated past 80 - my front end started to shake so much I thought the wheels were going to come off. Did the same thing every time I reached 80+.
Next day, and ever since - no more rain and everything's fine. Took it past 100 a couple of times and no problem. What's up with that?
Old 05-03-2005, 02:13 PM
2001CLK's Avatar
2001 CLK320, 2003 E320
Have you guys inspected your steering dampner..
Check for leaks in the cylinder. Very cheap and easy to replace.
THis could solve your vibration problem.
Old 05-03-2005, 02:15 PM
yuanja888's Avatar
Yes, i replaced mine last year and it was only $20. made some difference.
Old 05-03-2005, 02:58 PM
GrantWinTX's Avatar
CLK 430
My issue is different. I have no vibration (except when tyres are cold) BUT I do have a vibration under heavy braking when excess of 70 mph. Any ideas?
It may be brakes but they are new, balancing has been done several times. Is it possibly steering vibration damper?
Old 05-03-2005, 02:59 PM
GrantWinTX's Avatar
CLK 430
$20 from where??
Old 05-03-2005, 05:15 PM
yuanja888's Avatar
Originally Posted by GrantWinTX
$20 from where??
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
If you feel vibration only during braking... doesn't matter how hard it is most likely your rotors are warpped.
Old 05-03-2005, 09:07 PM
es202's Avatar
CLK
good infos in here.... maybe mine needs to change the steering damper & the tie rods. cause my rotors are brand new and same goes for the tyres
Old 05-04-2005, 01:58 AM
x15jq's Avatar
ur rim can be bent. when you hit the brakes you are puting more load on the tire/whls in the front, and this will make any bend more noticelable. I have had this problem in the past.
THe tie rod is a one piece assembly on the clk as well.
Old 05-04-2005, 02:59 AM
clkal's Avatar
01' CLK55
they should have charged you $700 cuz you got too much money...LOL
Old 05-04-2005, 04:13 AM
smalldog's Avatar
clk
Where is it located? Also when the dealer replaced my harmonic balancer they replaced a vibration damper. Is that the same as the steering damper?
Old 05-04-2005, 09:06 AM
str8ridin's Avatar
05 E55
Brake pads are new? Sounds like your rotors are warped.
Old 05-04-2005, 09:09 AM
GrantWinTX's Avatar
CLK 430
Pads and rotors are new. I put on the Zimmerman cross drilled rotors and ATE pads. I'm now wondering if the quality of these rotors is not that great and warp under any kind of heat.
Old 05-04-2005, 09:49 AM
smalldog's Avatar
clk
Just called the dealer......The two parts are different
Old 05-05-2005, 02:42 AM
D-5
D-5's Avatar
2003 E55
oh that's why!! I was on my way to seattle yesterday and my steering wheels shaked like crazy between 60-70mph. I had my wheels balanced last month so it must be the steering damper or the tie bar! I'll have it check out tmr.
Quick Reply: Steering vibration
