OBD 2 Socket in the Car?
Old Aug 10, 2005 | 11:48 AM
barflux's Avatar
CLK 320 Avantgarde
Is there a 16 pin OBD Socket in the car? I see a rectangular outline near the hood release but wanted to know if that was it?
Old Aug 10, 2005 | 11:59 AM
viguera's Avatar
CLK 320
IIRC, as per the standard, the socket needs to be within 3 feet of the driver and inside the cabin. I'm fairly sure it's in the foot well somewhere on the driver's side. Seek, and ye shall find.
Old Aug 10, 2005 | 12:12 PM
barflux's Avatar
CLK 320 Avantgarde
Taken a picture. I don't think I have one - this is sealed unless I cut it?
Old Aug 10, 2005 | 12:41 PM
str8ridin's Avatar
05 E55
That dorsn't look like it.
Mine is on the right side, under the steering wheel and right above the driver's side vent. It should have a covered plastic cover on it with a lip to snap off the cover.
Old Aug 10, 2005 | 01:18 PM
barflux's Avatar
CLK 320 Avantgarde
Sorry, should have mentioned the car is in the UK right hand drive and 2000 Model (facelift)
Old Aug 10, 2005 | 01:48 PM
barflux's Avatar
CLK 320 Avantgarde
Better shot of Driver's side and the 36 pin in the engine bay
Attached Thumbnails OBD 2 Socket in the Car?-dsc00954-copy.jpg   OBD 2 Socket in the Car?-dsc00958-copy.jpg
Old Aug 10, 2005 | 02:06 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Obd 2
I believe the OBDII standard is for US-market vehicles only, I however could be wrong. On my 98 C43 it's below the steering wheel, on the horizontal portion parallel to the floor it has a hinged cover on it and is readily visible.
Barflux, if I took the photo you took of the same area on my vehicle. It would be clearly visible, I don't think you have an OBD outlet on your UK-spec vehicle.
Old Aug 10, 2005 | 02:21 PM
viguera's Avatar
CLK 320
That's where it is on my 320. It must be something with the UK-spec... that 36-pin port is nothing like what the 16-pin OBD-II port looks like, not to mention it's in the engine bay...
OBD-II standards say the port has to be within 3 feet of the driver, inside the cabin and needs to be accessible without any special tools... but I guess it's different for the UK. I've seen manufacturers hide the things behind flaps and ashtrays and stuff, so who knows...
Old Aug 10, 2005 | 05:37 PM
barflux's Avatar
CLK 320 Avantgarde
I am looking for an OBD Scanner, at least I know I need a 36 pin. Any suggestions of a 36 pin Scanner?
Old Mar 3, 2015 | 01:59 PM
Chr15e's Avatar
Clk200
The 38 pin connection is located under the bonnet on the top right corner under an plastic panel
Old Mar 4, 2015 | 09:51 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
ER, this post is 10 years old ??
