Rattling from underneath
02 S500
I just bought a 1999 clk 430. When i pull out of park i notice a rattling noise coming from underneath as im accelerating it continues but eventully tapers off. It will start to rattle again after stops but not every tim.
Any ideas what this may be guys?
CLK 320
Originally Posted by nopepper
so it should be covered under my original warranty?
If not, it's pricey... front is $400 and change, rear is $900+ (I know, my rear went out and was replaced not that long ago).
02 E55; 99 CLK430 (Sold)
I had the exact same thing. It was just the heat shield on the cat. The cat itself didn't need to be replaced. I had it in to take the resonator off anyway so the guy just welded it back in a few places and presto...no more rattle. Not everything is as complicated as it seems.
CLK 320
Originally Posted by jtbeche
I had the exact same thing. It was just the heat shield on the cat. The cat itself didn't need to be replaced. I had it in to take the resonator off anyway so the guy just welded it back in a few places and presto...no more rattle. Not everything is as complicated as it seems. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
01 CLK 320 Cabriolet
Where is the heat sink located? I am getting rattling noises under the car while idle and when it first starts accelerating then diminishes. Need to figure this out and don't want to spend a fortune to fix it.
Also I read somewhere that these are under warranty for 80k miles...what if you purchased the car used? Even though I dont have a warranty are the parts still warrantied?
Most likely its the catalyic converters. When I just bought my CLK, it also had the rattling noises. I replaced the catalyic converters and that solved the problem.
2005 CLK 500 Coupe
I am having the same problem right now, and looking for the best solution.
I have 2002 CLK 320, and confirmed that is the Cat Converter.
People told me to go to muffler shop to replace the aftermarket converters.
I have called the dealer, the whole thing is $900+, plus $230 labor. So your cost is around $1100, $1000 if you go to do it from other shop.
However, I think each aftermarket converter is around $250, but we have 2 converters. So the price for the aftermarket is around $500.
The different is around $500-$600, but you get an original brand new converters which contains 4 new converters (2 front, and 2 middle) with pipe.
I will go for the original one right now, but I will go to muffler shop to check if there is any cheaper deal tomorrow.
By the way, 8y/80000 is the warranty of your cat. converter.
