Headlight covers
Old Aug 25, 2005 | 08:42 AM
nopepper's Avatar
02 S500
Headlight covers
does anyone know if you can just replace the cover and not the whole unit. If so, where can i get the covers?
Old Aug 25, 2005 | 12:16 PM
Josh K's Avatar
Tesla Model S
You can't, you have to replace the assemblies.
Old Aug 25, 2005 | 03:16 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
well.... by dealer standards, probably...
however, i'm sure you can go about finding a used/damaged assembly (broken mounting tabs) and switch the covers... it will take some work, but, it can be done...
Old Aug 25, 2005 | 03:35 PM
Josh K's Avatar
Tesla Model S
well...YEAH, I guess lol
Danny's always gotta one up me lol
I figured if he wants to replace the covers then he most likely wants them to look new again ;0)
Old Aug 25, 2005 | 03:47 PM
mmgrad's Avatar
i ain't one up on you... i'm just a distant shadow of ur CLK...
i just figure, maybe he got a nasty gash or scratch on his lens... and would be cheaper to just buy a light with a busted tab or something and swap covers... of course, its no easy job to do it, but, it can definitely be done...
Old Aug 25, 2005 | 04:29 PM
blackbenzz's Avatar
haters crazy
If you want to swap covers all you have to do is stick them into the oven til the glue gets soft, then switch.
Old Aug 25, 2005 | 07:56 PM
midget fidger's Avatar
E550 Coupe
you've done that before?
Old Aug 25, 2005 | 08:33 PM
ThrillKill's Avatar
CLK/ML
I did.
http://forums.mbnz.org/forums/forums...osts=21&fid=20
Old Aug 25, 2005 | 08:45 PM
Co 55 AMG's Avatar
W208
Originally Posted by ThrillKill
That mod came out bad a$$!!
Old Aug 25, 2005 | 08:49 PM
ThrillKill's Avatar
CLK/ML
Thanks!
Sup' Josh?
Old Aug 25, 2005 | 09:58 PM
mmgrad's Avatar
the oven is the fast method of doing it, but be VERY careful because too much heat and it will deform the light...
a safe route would be to just use a blow dryer... its a little slower, but, just as effective... done it several times on various headlights
Old Aug 25, 2005 | 10:30 PM
E550 Coupe
wow, clever...where'd you get all the parts for the projector conversion and everything? did you buy that one on ebay for the e-class then swapped the lense?
Old Aug 26, 2005 | 12:12 AM
ThrillKill's Avatar
CLK/ML
No, it's the front clear lens for CLK with oem HID reflectors. Got everything on Ebay, heh.
Old Aug 26, 2005 | 12:15 AM
ThrillKill's Avatar
CLK/ML
200 degrees F for ten minutes, safe as can be. Just make sure you remove bulbs and put the housings on a cookie sheet and don't let them touch the oven surfaces. Use a wide dull butterknife to pry them apart.
Old Aug 26, 2005 | 01:02 AM
mmgrad's Avatar
200 degrees is more than enough... 150 is good enough to do the job, and more than enough to be effective... just in case anyone ever wants to try it for themselves...
anything in the middle would be a fair compromise as well...
how do you like the overall projector effect? i have been thinking about doing the same...
i've had a set of bi-xenon projectors sitting arround just waiting for me to put them in.. been sitting in my office for like 2 yrs now... maybe i should start putting it together soon :d
Old Aug 26, 2005 | 08:56 AM
ThrillKill's Avatar
CLK/ML
Amazing! I finished install late and didn't aim them. Driving home last night I was lighting up overpass signs a MILE AWAY!! People were getting out of my lane...Clear shot home. I'm fortunate not to have been shot by a road rager. I aimed them when I got home and made my wife drive around the block to scope the look. It was there.......The much coveted "blue flicker"..... worth doing the mod alone imho. With bi-xenons you'd have 2 sets of high beams . There is a guy on HIDPlanet named zam2000 who did a bi-xenon (LS430) install in his Eclass....He can light up 5 lanes of highway!!!
Edit:
After reading old email zam actually did not use bi-xenons and I'm thinking you would need a switch to activate the high beams unless they can be spliced into the present high beam configuration........Dude, it would look like the Close Encounters mothership with those suckers blazing together.....Go for it!
Old Aug 26, 2005 | 10:27 AM
mmgrad's Avatar
haha... zam2000 is also on this forum... and i've seen his HID conversion, and it looks sick ....
Old Aug 26, 2005 | 06:09 PM
King320's Avatar
03 C32 AMG
Im just sick of my headlights looking all brownish yellow, i heard that some guys on mustang forums have the same problem and have a good cleaner that eats off the oxidation, but TOGWT also said on the detailing forums that if they're oxidized thru the plastic, nothing will help.
Old Aug 27, 2005 | 08:16 PM
ThrillKill's Avatar
CLK/ML
Some people have good results with C.L.R. You can also use Maguires polishes but once you remove the protective coating they are exposed to uv rays and you have to repeat the process every 6 months or so.
