My Supercharger :0)
Rating: Thread Rating: 2 votes, 5.00 average.
Old 11-13-2005, 04:43 AM
  #101
OJwerks's Avatar
not stock.
Cool
Josh K, what model of blower are you running in your kit?
BTW, very very nice, exactly what im going to do in my 320 SLK.
Old 11-13-2005, 06:24 AM
  #102
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by mtimmy
HAHAHH., THANKS SOOO MUCH for clearing up my
yeah., so I will be looking in to those Bosch..
btw., I found out the GREEN bosch is 42lb... IF this is the SAME green we are talking about.
KOOL! And Mario(E55cent) told me that the company that makes the fuel and timing control is called Split second.PM Mario for details. This supercharging,inj,fuel and timing thing is not hard.Good Luck!PS and try Ebay once you figure out what injectors you'll need.
Old 11-13-2005, 12:34 PM
  #103
OJwerks's Avatar
not stock.
anyone????? coming from highly modified custom turbo setups on 1.8T vw engines (Audi TT, Audi A4 and Jettas) ive seen my fair-share of those BOSCH injectors...etc. Ive been trying for a while to get every-sort out for my custom supercharger setup but its really hard since all the "high-end" custom shops here are scared as hell from working on MBs (but they fill at home with the bmws / vws)..and I shortly found someone that is dying to work on my car ....good old friend that hadnt seen in a long time. ROTARY-powered champion in the state of florida. Ran 7 seconds with a little 1.1L engine
Old 11-13-2005, 08:21 PM
  #104
Josh K's Avatar
Tesla Model S
My kit uses a Vortech V-1 SL polished blower.
Old 11-14-2005, 01:00 AM
  #105
newguy2008's Avatar
CLK 55 ///AMG Cabrio, ML63 ///AMG
Again, Sick Bro!
Vortech for those who don't know have been in the business for many years.
I need someone here in Toronto, Canada to blow my Cab. I need to move to Cali.
-Frustrated Canadian.
Old 11-16-2005, 08:41 PM
  #106
Co 55 AMG's Avatar
W208
Originally Posted by newguy2008
Again, Sick Bro!
Good one.
Old 11-28-2005, 03:36 AM
  #107
SLVRBLT43K's Avatar
05 sl600, 06 CLS55 AMG, 1971 Cuda
Very nice. Only thing I would worry about is the rear differential.
Old 12-09-2005, 09:55 PM
  #108
joeybenz106's Avatar
2007 cls 550
what are u using to tune the car if u dont mine me asking. i think thats a great setup!
Old 12-10-2005, 02:52 PM
  #109
Josh K's Avatar
Tesla Model S
Currently it's running stock software (custom ECU is in the works) and is tuned with an adjustable fuel pressure regulator.
Old 12-10-2005, 03:22 PM
  #110
ProjectC55's Avatar
Any hints? I think it's better to upgrade the fuel pump vs just adding an adjustable fuel reg.Just my .02.
I'm interested in knowing the results,keep us posted.
Old 12-10-2005, 03:53 PM
  #111
Josh K's Avatar
Tesla Model S
Actually right now, the stock fuel pump flows more than enough fuel to hold the needed PSI at the rail. The car runs great and doesn't detonate on pump gas. It does lean out a little bit at the top (not enough to harm the motor), but this is due to the ME2.0 software in the car right now - the problem is not present on 2001+ cars with ME2.8. The ECU will address this issue. :0)
Old 12-10-2005, 04:25 PM
  #112
ProjectC55's Avatar
Ever considered using a piggy back that can adjust timing and fuel? I think this is better than just programming a chip, especially for F/I.
When I go F/I this will be my route.Mario's E55 uses ME 2.0 software and the car runs rich I believe he says.So I guess each will run different.You can program the ME 2.0 software to run rich. I still stand by piggy back or standalone though.
Old 12-10-2005, 09:34 PM
  #113
Josh K's Avatar
Tesla Model S
Well the chip wouldn't be a mail order one, it will be programmed and adjusted with the car on the dyno (full custom tune).
Mario's car uses ME2.0 but he's also got a 55 (different injectors, etc.) I was thinking about going standalone, but I want to keep it smog legal and I'm not sure how standalone would fit into that.
Either way, I'm just trying to squeeze the most ponies I can out of the current setup. Right now it runs great with no drivability issues whatsoever, so I'm already pretty happy.
Old 12-12-2005, 11:16 PM
  #114
CHB
CHB's Avatar
'79 300D, '85 300Dt, '99 CLK430
Have you had time to take it to the track yet? Can you give us a teaser in car video please :p
Old 12-12-2005, 11:37 PM
  #115
Josh K's Avatar
Tesla Model S
Well now that I'm done with school forever, I'll have more time for the fun stuff, so yes all of that's coming :0)))
Old 12-13-2005, 12:02 AM
  #116
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
Josh lets set a time for us and other supercharged Benz's to go to the track. I'm getting ready to buy some drag tires. What do you think?
Mario
Old 12-13-2005, 12:41 AM
  #117
Josh K's Avatar
Tesla Model S
Mario
Sounds like a plan. I just found a set of 10" wide rears for my car so I'm gonna get them stripped and powdercoated to match my current wheel color. I was having a hard time getting traction last night so hopefully some 275's/285's back there will help.
What track are you thinking about?
Old 12-13-2005, 01:09 AM
  #118
CHB
CHB's Avatar
10" wide rears, so hopefully some 275's/285's back there will help.
If you make those tires fit without rubbing, please post specific details on how to do this.
Old 12-13-2005, 01:22 AM
  #119
Josh K's Avatar
Tesla Model S
I most certainly will. I'll more than likely have to roll the fenders, especially considering that I have adjustable camber arms so I can't use the excessive negative camber to tuck the wheels :0) Either way, details will be posted.
Old 12-13-2005, 10:54 AM
  #120
E55Cent's Avatar
Not sure what track is the best around here. Bakerfield, Palmdale or ????
Are you having F1 roll and stretch the rear fenders? They might have to cut and remove the whole inside fender, this is what they did on my Bimmer.
Old 12-13-2005, 12:41 PM
  #121
Ghostrider's Avatar
01 CLK 430
I did the same thing, then had the underside coated for rust protection.
Old 12-13-2005, 12:52 PM
  #122
Josh K's Avatar
Tesla Model S
Palmdale isn't usually crowded but you run about .5 seconds slower there cause of the altitude. I guess we could check out pomona or Carlsbad.
As for the fenders, my friend has a fender roller, I'll probably do it myself unless it involves trimming.
Old 12-14-2005, 04:02 AM
  #123
SLVRBLT43K's Avatar
You are not worried about your rear Diff???
Old 12-14-2005, 04:03 AM
  #124
vraa's Avatar
Josh makes rear diffs while he sleeps so he doesn't need to worry about it!
Old 12-15-2005, 12:21 AM
  #125
SLVRBLT43K's Avatar
HMMMMM!!!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: My Supercharger :0)
