Rubbing on the driver side rears with 19"
1. the driver side rear rubs when hitting little bumps, looks like its hitting the very top of the fender. its also a little lower on the driver side than the passenger side on the rear.
possible solution: put a #4 spring pad in the driver side rear?? hopefullly it will even out the uneven height issue. this means i will be running #4 pads up front and a #4 in the driver side rear...and #3 on the passengerside rear. sounds okay???
2. the 19's howl a lot louder than the 18's brabus I had. the rear tires are michellin sport, and the front are nitto's.....are they known for more road noise...or is that the nature of the beast when going to 19's, cuz my 18's with falkens where quiet....
anyways...any thoughts or input would be great!
thanks,
George...
ps....maybe i should take out my subs for now and reduce the weight in the back?
seems like its rubbing on the point of the fender where it meets the bumper..i can see rub marks on the tires from this....
not sure what else to do at this point
ps. running stock shocks, eibach's, and lexion 203 rims
