BAS and ESP light - mailfunction
Old Feb 4, 2006 | 10:15 AM
wmhjr's Avatar
Last night, got in my car to drive home from work (1hr drive). About 15 minutes into the drive, I heard a bell go off and then my cluster display said that I had a Brake Assist (BAS) problem, and then an Electronic Stability (ESP) problem. The BAS/ESP light was on in the lower left side of the instrument panel. When rotating through the cluster display again, going back to the malfunction screen indicates 3 malfunctions. One was a light bulb out (which I already knew about) and the other two were BAS and ESP.
The car seemed to drive fine for the duration of the trip. I had to make one brief stop (about 15 minutes). When I got back in, the lights did not come back on. The remainder of the drive was only about 5 minutes after that.
I believe it's about time to change brake pads.
Any idea of where to look other than just taking it to an MB Benz dealer?
Thanks!
Old Feb 4, 2006 | 07:02 PM
clkgeorge's Avatar
00 clk 320 and 3 hondas. Darn I am down to 4 cars.
Do a quick search on BAS on this forum. There are lots and lots of threads about this problem. The most common cause is the brake light switch located at the brake pedal
Old Feb 5, 2006 | 11:21 AM
wmhjr's Avatar
I did a search. All of the posts I've found also include the ABS light coming on. In my case, the ABS light did not come on. That's why I asked.
Old Feb 2, 2007 | 04:35 AM
SeNia_CLK's Avatar
2001 CLK 320
I got the same problem today coming back from a friends house..the car has been siting in -16 wheather... Anyone had this problem before? The ABS light didn't come on however... so it is not a brake switch! Guys need your help on this one!
Old Feb 2, 2007 | 11:28 PM
SeNia_CLK's Avatar
2001 CLK 320
Ok well the problem magically disappeared today... I think it was the cold weather
Old Feb 3, 2007 | 01:40 AM
mbdreamr's Avatar
1987 190e 2.3-16 sold and missed, 1966 220s, 2016 GL550, 1999 C43, 2006 CLS 55
i had the same problem with my 2001 clk430, and i found out that it was the brake light switch that is located behind the brake pedal. this is a common problem for these cars. it's about a $15 part, and you can change it yourself
Old Feb 3, 2007 | 10:18 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Sometimes it happens when you don't push the brake pedal down enough.
Restarting the car will clear the warning codes.
If it keeps happening, you most likely need to replace the switch.
Old Feb 3, 2007 | 02:49 PM
SeNia_CLK's Avatar
2001 CLK 320
You should pay more attention to things I say
