Still have ABS Malfunction after switch replacement
Now, I re-checked the connection to the switch and they are on there properly. So what else can make the light come on AGAIN!!
Has anyone else ran into this?
http://www.benzworld.org/forums/w208...luid-leak.html
Hmmmmmmmmmm my washer fluid light is also coming out and running out within days after being filled and not using..I will read the link!!
I also have the washer fluid problem that runs out within days after filling it all the way up and not using it along with the ABS sensors at the same time even after replacing the switch. But he doesnt give a good explanation so I asked for more info. Any more info on this problem???
...taken from the other list....Calibrate your ABS and ESP systems by turning the steering wheel all the way to your RIGHT and then all the way to your LEFT, then bring it back to the middle. Not sure of key position.
Actually...no I didnt even know we had to calibrate it!!
I will have to look this up now and try it!! THANKS
