Does W211 brakes fit in W208??
Hey I have a friend that selling w211 brakes(Front and rear). Do you guys know if these brakes(Calipers) fit our w208 directly?? Do I need some kinda modification or so?? Help me to upgrade guys...
E320CDI, CLK55, and a Smart
Yes, anything is possible. I fitted E55 w211 brakes on my w208 CLK55. The front hubs have different diameters so I had to get custom rotor hats made for the front. Do not expect this to be an easy task. There is ALOT of custom work that has to be done in order for this to work.
Is it hard to do the custom jobs?? Where do I have to take them to?? Regular brake shop?? I don't have a lot of information about the brakes.. Or I rather get a C class brakes?? Thanks guys..
A regular brake shop wont touch this at all. A machine shop is your best option. Even then, you will have to tell then what you want to do. If you are looking for a bolt on system, go for the C32 brake setup if you want a BBK in the front. There is no easy BBK for the rear other than brembo. I have the Brembo BBK for the front and rear for $3500 which is over 1/2 original price. This is a bolt kit and no customization is required.
Thanks for the offer dan **** but Iam kinda short now... Anyways thanks for the info.. I'll try to look for the c32 brakes... thanks anyways,,
And also, where can I get the cheapest c32 brakes?? Any shops would you guys recommend?? Thanks... or any private sellers around???
2000 CLK 430
Originally Posted by Dan ****
no problem... If I were you spend about $500 on a used set of C32 calipers and rotors/pads.
The brake kit from any year c32 would fit on a 2000 clk430?
W208 CLK230K Convertible, R231 SL400, W222 S450L
How much heavier are the C32 brake fit as opposed to
How much heavier are the C32 brake fit as opposed to the stocks. Or the W211 ? Is it W211 > C32 > Stock ?
Was planning a C32 retrofit but may not if they are too heavy and will slow me down
Originally Posted by Josh K
yeah, they can be made to fit. they look great but they're VERY heavy and will no doubt slow your car down a bit.
