Idle Vibration
Old Mar 22, 2006 | 10:10 AM
cnotes999's Avatar
2001 CLK 430
Idle Vibration
Ok about a week ago I had a check engine light come on and my friend who has the diagonstics machine plugged it in and told me that the MAF need to be replaced which I did last night..now the vibrations arent so bad when im idiling at the light but they are still there..also my check engine light didnt go away, but I disconnected and reconnected the battery and the light hasnt come on since..but now I worried about this vibration when Im idiling...could my mounts be bad? any input would be appreciative. Also one more question, if the transmission fluid was a problem would it come up on the dash computer and specifically tell me that there was a transmission fluid problem or would it say check engine? I do not see a dip stick anywhere to check the tranny fluid...thanks again
Old Mar 22, 2006 | 02:48 PM
cnotes999's Avatar
2001 CLK 430
anyone???
Old Mar 22, 2006 | 03:15 PM
Renault78law's Avatar
2003 C32
have the engine mounts checked
Old Mar 22, 2006 | 03:26 PM
cnotes999's Avatar
2001 CLK 430
thanks will check it out
Old Mar 22, 2006 | 03:51 PM
Spriro's Avatar
1999 C280
Yes, probably the engine mounts. Just fixed mine last weekend:
Pic
Old Mar 22, 2006 | 04:39 PM
cnotes999's Avatar
2001 CLK 430
also what about a dipstick for the transmission fluid..is there a way to check?
Old Mar 22, 2006 | 04:53 PM
Spriro's Avatar
1999 C280
If I'm not mistaken, near the firewall in the middle, maybe more towards the passenger side there is a dipstick tube with a cap on it but no dipstick. I don't know if that's the one to check the transmission fluid or not. Maybe some expert here can tell you more about it. I remember reading something about it a long time ago. I believe you need to buy the dipstick from the dealership parts dept.
My transmission gasket was leaking for about a month period one time. I did not get any warning light on my cluster.
Old Mar 23, 2006 | 02:04 AM
bs00clk's Avatar
2000 Silver CLK430
Pic
Hey Spriro, was this on a CLK or on your C280?
Old Mar 23, 2006 | 09:47 AM
Spriro's Avatar
1999 C280
This is my C280.
Old Mar 24, 2006 | 09:14 AM
cnotes999's Avatar
2001 CLK 430
ok well i come to find out that there isnt a tranny leak and my check engine light has went away after changing the MAF but I do notice that when the gears shift I hear a grinding noise only when it shifts but then after that there is nothing..to describe the noise is hard because its not loud and its a quick grind the same way the gears shift
Old Mar 27, 2006 | 04:04 PM
cnotes999's Avatar
2001 CLK 430
bump anyone? the light is still on, i would just like to have some kinda input so I do not have to go to the stealership and it costs me an arm and a leg...
Old Mar 27, 2006 | 05:49 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Dealership may be your only choice. Lots of independents rip you off because they don't sell cars and don't have any incentive to have you return.
It most likely are the engine mounts.
Old Mar 30, 2006 | 09:22 PM
cnotes999's Avatar
2001 CLK 430
thanks man i appreciate it.. now i gotta go to the stealership..
