DIY radiator flush help needed
Old May 27, 2006 | 03:55 PM
joeray's Avatar
2000 CLK 430 Conv.
I am planning on flushing the radiator this weekend, but this is the only link I found as to how to do it when I searched for "Radiator flush":
https://mbworld.org/forums/showthrea...radiator+flush
The above doesn't go into detail as to if the engine should be hot enough for the thermostate to open so that all the fluid come out, etc.
Can somebody explaine the different steps to do this?
Should I drain the fluid when the engine is hot or cold, the first time?
do I leave the engine on when the fluid is coming out, etc.
thanks
Old May 27, 2006 | 11:24 PM
Martin's Avatar
CLK320, Carrera S
You must do it when the car/engin is cold. All the fluid will drain out. Flush like it says and refil.
