3.5 Liter 280 HP vs 4.3 Liter 275 HP?
Old May 30, 2006 | 11:09 AM
wnycec's Avatar
2000 CLK 430
Why and how does the G35 coupe put out more horsepower than our bigger engines?
I am not very knowledgeable about engines but I just wanted to get some explanations.
Its normally aspirated and 3.5 liters
I'm normally aspirated and 4.3 liters yet my hp is slightly lower than the G35.
Forget looks, lets just discuss engins here - where did my HP go?
Old May 30, 2006 | 11:37 AM
E55Freak's Avatar
2005 E55 silver
infiniti-10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35DE
CLK-4.3-Liters V8 SOHC 24 Valves 10.1 compression.
The compression is slightly higher in the Infiniti and it has a double overhead cam. The CLK only has a single.
Old May 30, 2006 | 11:43 AM
wnycec's Avatar
2000 CLK 430
How would you increase compression ratio?
I am assuming a supercharger does that but how would u do it without a supercharger?
Old May 30, 2006 | 12:49 PM
E55Freak's Avatar
2005 E55 silver
usually, you have to replace the cylinders if you don't want to supercharge it. This is fairly cheap on the good ol american muscle cars..but I don't know if you could find different cylinders for the CLK. I would think the cost would be about the same to just get a supercharger. But the higher the compression, the higher octane gas you'll need to get. Also, if you raise the compression of a naturally aspirated car, then you can't really supercharge it..it would be way too much. Usually when you get above 11.5 that is almost "race" only. I think the new 63 motor is gonna be around 11 to 1. So, that is gonna be tough to supercharge.
Old May 30, 2006 | 02:33 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Don't forget to discuss torque output as well. The CLK 4.3 litre puts out 295 lbs of torque. Also, HP numbers can be considered "best results" or "optimum output." Some engines in real life scenarios may put out a little more.
I dyno'ed my car and it did 245 hp/ and 251 torque at the wheels.
Old May 30, 2006 | 04:07 PM
wnycec's Avatar
2000 CLK 430
Well I was on the road about a month back when a 350z drove by me and recognized that I was a worthy advisary to take on... as he passed he dropped his speed down and turned on his flashers as to get my attention
he pulled nose to nose and I knew it was on... from a rollin start... at about 65/70 mph... we both floored it and I ended up gettin the best of him
How do you explain that?
lighter car, more HP versus my v8 beast.
I am completely puzzled.
Old May 30, 2006 | 05:27 PM
myNAMESterry's Avatar
991.1 gt3, w204 c63 507
it's the high end torque YO! yeeeeeeeeeeeeeeeeeeeeeee
Old May 31, 2006 | 12:46 AM
clkal's Avatar
01' CLK55
ROLLING start, and higher speeds, your 430 will take the 350z....especially on the freeway, your V8 really makes a difference.
Old May 31, 2006 | 02:41 PM
Hal H's Avatar
2001 CLK320
The major differances will be the 4 valve / cyl and variable cam timing.
The M113 (and M112) engines have 3 valve / cyl and fixed timing. At the time, M-B found the 3 valve head produced lower emissions that the earlier 4 valve head.
Now with direct injection gasoline engines, there's even more precise control over the fuel / air ratios and higher ECM computing power in the newer designs.
The higher comp. ratio will help, but the 4 valve heads will flow more air.
The new Benz 3.5 V6 has 4 valve/cyl, variable cam timing and direct injection which allows higher comp. ratio. This engine is rated for 268hp for the V6 vs. 275hp for the 4.3 V8.
It's simply the better breathing heads that allows more power. The new 4 valve 5.5L V8 in the '07 S-class is another example - its displacement has been bumped up over the old 5.0 V8 M113 engine, so that's another factor as well.
Old Jun 1, 2006 | 02:24 AM
55 ON IT's Avatar
W208 CLK55K, GTR, RS5
Simple fact. HP sells cars, torque wins races.
Old Jun 10, 2006 | 10:10 PM
Josh K's Avatar
Tesla Model S
What most people fail to realize is that it's not simply low end torque that wins races, but the ability for an engine to continue producing consistent torque all the way to redline. Some of the meaning gets lost in the catch-phrase. ;0)
The 430 will take a G35 on the highway because of its gearing, but off the line a stock 430 will get its *** handed to it by a stock G35 (though not embarrassingly so).
Old Jun 11, 2006 | 01:27 AM
55 ON IT's Avatar
From reading numerous post, I always thought that the G35 vs. E36 M3 was always a driver's race. I've also read that numerous CLK430s have beaten or were pretty even with E36 M3s. If I remember correctly, I believe you've posted a kill awhile back also (pre f/i). So, to say a G35 would hand a CLK430 it's *** may be a little harsh.
But, I believe my quote is pretty accurate. Kind of goes hand and hand with the whole E55/M5 debate.
Old Jun 12, 2006 | 01:28 AM
wnycec's Avatar
2000 CLK 430
usually when I see an M3 on the road - I concede to them... maybe next time i'll try testing my 430.
I'll make sure to get a CLK 55 Airbox on my car first though. Give me an extra umph...
Old Jun 12, 2006 | 11:04 AM
alsamrob's Avatar
clk430
I had that engine, and while bulletproof in terms of service, I wished I had not traded it for for my old '97 E320. Back now with a CLK430 Cabriolet, and while "sluggish" off the line, it handily takes care of the ricerockets on the highway. The Infiniti/Nissan engine is very quick but lacks any real umph once you get past 70. I've found my whip is very quick 70 -110, not to mention much more stable
