Interior Squeaks
Old Jul 19, 2006 | 01:46 PM
chem1441's Avatar
2016 C450 AMG
Interior Squeaks
I know there are a lot of posts on here about this, but I can't seem to find an answer.
1. The rear deck rattle when the bass hits. Is this something I can fix, or can dealer fix?
2. The driver seat squeaks on the door side everytime I go over a bump or speed bump. It drives me crazy. I can't tell if it is plastic rubbing, or a metal spring, or something else. Is this something I can fix, or can the dealer fix?
I have an extended warranty, but it will not cover these items, so Im curious if anyone has had this type of work done at a dealer, and how much it cost?
Old Jul 19, 2006 | 02:47 PM
rubberninja's Avatar
2002 CLK55 AMG, 2005 C240 4maitc
This'll do the trick
www.quietcar.net
(as far as the seat squeaking and what not, same thing happenes in my car. It's just because of the plastics and whatnot used for parts, not much you can do except use quitecar and make sure everything is lubed up nice)
Old Jul 19, 2006 | 09:58 PM
threesticks03's Avatar
1999 CLK 430, 2006 SL 55, 2006 Range Rover Sport, 2006 F-150 Super Crew
Rattles, ticking, squeeks
https://mbworld.org/forums/c-class-w203/88346-rattles-ticking-knocking-rattling-diy-fix.html
Old Jul 28, 2006 | 09:24 PM
chem1441's Avatar
2016 C450 AMG
I was gonna put some fussy velcro on the side of the drivers seat...but it is so tight between the fabric and the plastic...how does anyone fit anything in between there? I half wanna just take it to the dealer and let them fix it, but Im afraid of what they would charge for a velcro fix....
Old Aug 1, 2006 | 11:07 AM
doramon's Avatar
W208 CLK 320 Yr 2000 & W203 C200K Yr 2003
wat i did was use the material used to wrap those mdf boards when u do any installation for amps of subs.....cut them to the shape and just slide them in between the leather seat and the plastic thingy....results...no more squeeks
Old Aug 3, 2006 | 12:37 AM
midget fidger's Avatar
E550 Coupe
I used a couple old socks to fix the rear deck rattling haha. I stuffed them in between the subs and the metal.
Old Aug 5, 2006 | 12:13 PM
RDD's Avatar
RDD
03 M3 coupe 6MT, 05 A6 (wife + kid's)
For the driver's seat, look under the seat from the back. See those white plastic tabs on either side? Cover them with felt and see if that helps. I covered just the top of them with felt but my squeaking was still there. Then I covered the ends/tips of them and now no more squeaking.
