So, ..... why are we spending money for brake switches?
Old Oct 29, 2006 | 01:30 AM
The Jury's Avatar
2002 c240
When I first got my CLK430 I came here and found the fix for my 3 lights. Like a sheep, I replaced the brake switch against my will (since they are $26 a pop at MY dealer) and followed the flock.
Well, being an electronics specialist I wanted to know why it failed since inevitably it will fail again next year (according to everyone here). I can't believe I went against my will and bought one of these things! There are no electrical components inside at all, just a dang contact sitting on a spring.
People, please do yourself a favor and clean this contact if you are having trouble. It's ridiculous to tell people to buy a new one just because there's a little corrosion on the contact.
Save the $26, that's nearly a tank of gas in my area!
Old Oct 29, 2006 | 01:41 AM
The Jury's Avatar
2002 c240
Here's the bottom contact which looks ok, but should be checked anyway while you are in there.
Old Oct 29, 2006 | 01:51 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
I’ve never had this problem ever, could you please elaborate what the problem is, and where this piece is located?
Old Oct 29, 2006 | 03:37 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Good info!
Amazing that the switch just a simple electrical contact. I tried prying my old one open to see the inner workings but had a tough time getting it apart. Will definitely work the cleaning next time it gives me troubles. Thanks for tearing into the problem further.
Old Oct 29, 2006 | 04:02 PM
funky102's Avatar
2000 CLK 320
Good info! I wish a tank of gas was $26 in my area
Old Oct 29, 2006 | 09:16 PM
software's Avatar
2014 E550 Convertible
Mine was definitely broken
When I replaced my switch the old one sounded like a baby rattle. My guess is one of the contacts had broken loose. I'm usually good at fixing these things, but my dealer is close and only charged $18.
The car had 105,000 miles when I replaced it, but had been sporadically giving lights for some time. I bet the contacts were dirty, and cleaning would have helped. I wish I had taken it apart to see what was rattling.
By the way - except when it was raining my car was much more fun to drive with all of that "stuff" disabled!
Old Oct 29, 2006 | 09:51 PM
ThrillKill's Avatar
CLK/ML
Don't recall anyone in my area ever having this problem. Seems like it's always west coast or east coast people. Salt in the air?
Old Oct 30, 2006 | 05:07 AM
Spining's Avatar
MB CLK 200 kompressor cabrio w208
never had this problem...
Old Oct 30, 2006 | 04:53 PM
platinumney's Avatar
clk 320 pioneer FB 90 Chrome Halo projector headlights
thats awesome
Old Nov 1, 2006 | 03:35 PM
zdfun's Avatar
2005 CLK 500 Coupe
Thank you for your info. I have just replaced one for $17, so I can follow your instruction to play with the old one. Therefore, I always have a spare one at home.
Old May 8, 2007 | 09:34 PM
AustinRoxy's Avatar
99 CLK 430
Cleaning it worked!!!!!!!!!!!!!!!Good advice
Cleaning it worked!!!! Good advice
Old Dec 3, 2018 | 08:20 AM
wiseass's Avatar
big bump!
I've got this switch out of my w204.
is it repairable? i wont be able to get a new part until next week.
thanks
Old Aug 27, 2024 | 10:44 PM
ToplesSadie2003's Avatar
CLK 320
Exclamation i Cleaned mine, still didn't work cause missing brake light socket.
New Battery, New Brake light switch, new wheel speed sensor, cant find the proper order to diagnois this anymore. If anyone has it please share. My wheel speed still says 650kmph even though it new. What?
Vehicle:2003 Mercedes CLK320 Cabriolet (W208)
Customer:ToplesSadie2003
Operator:WDBLK65G53T136559
Date(D/M/Y):25/08/2024
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>Module Information:
Control Unit: ME28
Supplier: Bosch
MB Number: 1121533779
Hardware Status: 04/02
Software Status: 11/02
Diagnosis Identification: 01/07
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>Read Fault Code:
Total Number : 1
P2030-004 1/1
State: Current
CAN data from control module N15/5(Electronic selector lever module control module) or A80(Intelligent servo module for DIRECT SELECT) is missing or faulty, Communication fault / See also CAN state in freeze frame data(P0600)
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check drive authorization:
Total Frame: 1 , Supported Items: 4
Frame 1/1:
199 Immobilizer ----- Not Active
276 Serial number ----- 0135815721012201
196 Start enable ----- YES
197 Status of drive authorization ----- Immobilizer is activated
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check engine at cold start and in warming - Up phase:
Total Frames: 33 , Supported Items: 16
Frame 1/33:
001 Temperature of coolant ----- 44°C
003 B2/5b1(Intake air temperature sensor) ----- 38°C
004 Engine speed ----- 0rpm
011 Ignition angle ----- -54°
015 B6/1(Camshaft Hall sensor) ----- Nosignal
016 Battery voltage ----- 12.42V
042 Idle speed detection ----- ON
046 M33(electric air pump) ----- OFF
047 Y32(Air pump switchover valve) ----- OFF
052 Heating TWC(By altering ignition up to about 70 °C) ----- OFF
053 Post-start enrichment ----- ON
055 Safety fuel shutoff ----- OFF
379 Oil temperature ----- 36°C
380 Oil level(Engine not running) ----- 43.61mm
381 Oil quality ----- 2.20
Frame 2/33:
004 Engine speed ----- 215rpm
011 Ignition angle ----- -5.99°
015 B6/1(Camshaft Hall sensor) ----- SignalisOK
016 Battery voltage ----- 12.33V
380 Oil level(Engine not running) ----- 43.29mm
Frame 3/33:
003 B2/5b1(Intake air temperature sensor) ----- 34°C
004 Engine speed ----- 847rpm
011 Ignition angle ----- -16.49°
016 Battery voltage ----- 13.55V
016 Battery voltage ----- 13.74V
046 M33(electric air pump) ----- ON
047 Y32(Air pump switchover valve) ----- ON
380 Oil level(Engine not running) ----- 37.65mm
Frame 4/33:
001 Temperature of coolant ----- 45°C
004 Engine speed ----- 800rpm
011 Ignition angle ----- -20.99°
016 Battery voltage ----- 14.02V
380 Oil level(Engine not running) ----- 31.37mm
Frame 5/33:
004 Engine speed ----- 808rpm
016 Battery voltage ----- 13.93V
053 Post-start enrichment ----- OFF
379 Oil temperature ----- 38°C
380 Oil level(Engine not running) ----- 27.29mm
Frame 6/33:
001 Temperature of coolant ----- 47°C
004 Engine speed ----- 798rpm
011 Ignition angle ----- -22.49°
380 Oil level(Engine not running) ----- 26.67mm
Frame 13/33:
001 Temperature of coolant ----- 59°C
003 B2/5b1(Intake air temperature sensor) ----- 35°C
004 Engine speed ----- 744rpm
011 Ignition angle ----- -19.49°
379 Oil temperature ----- 43°C
380 Oil level(Engine not running) ----- 26.98mm
381 Oil quality ----- 2.18
Frame 19/33:
001 Temperature of coolant ----- 68°C
004 Engine speed ----- 713rpm
379 Oil temperature ----- 48°C
380 Oil level(Engine not running) ----- 28.55mm
Frame 25/33:
001 Temperature of coolant ----- 75°C
004 Engine speed ----- 704rpm
379 Oil temperature ----- 53°C
380 Oil level(Engine not running) ----- 29.80mm
Frame 33/33:
001 Temperature of coolant ----- 77°C
003 B2/5b1(Intake air temperature sensor) ----- 36°C
004 Engine speed ----- 701rpm
011 Ignition angle ----- -17.99°
379 Oil temperature ----- 59°C
380 Oil level(Engine not running) ----- 30.43mm
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check electronic accelerator:
Total Frame: 1 , Supported Items: 7
Frame 1/1:
001 Temperature of coolant ----- 81°C
379 Oil temperature ----- 67°C
380 Oil level(Engine at idle) ----- 31.69mm
380 Oil level(Engine not running) ----- 31.69mm
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check electronic accelerator(Full load):
Total Frames: 5 , Supported Items: 7
Frame 1/5:
004 Engine speed ----- 693rpm
021 B37(Accelerator pedal sensor)Signal 1 ----- 0.29V
022 B37(Accelerator pedal sensor)Signal 2 ----- 0.15V
023 M16/6(Throttle valve actuator)Signal 1 ----- 0.59V
024 M16/6(Throttle valve actuator)Signal 2 ----- 4.42V
043 Full load detection ----- OFF
058 Throttle valve stop learned ----- YES
Frame 2/5:
004 Engine speed ----- 684rpm
023 M16/6(Throttle valve actuator)Signal 1 ----- 0.58V
Frame 3/5:
Frame 4/5:
004 Engine speed ----- 4059rpm
021 B37(Accelerator pedal sensor)Signal 1 ----- 4.68V
022 B37(Accelerator pedal sensor)Signal 2 ----- 2.32V
023 M16/6(Throttle valve actuator)Signal 1 ----- 1.01V
024 M16/6(Throttle valve actuator)Signal 2 ----- 4.00V
Frame 5/5:
004 Engine speed ----- 4200rpm
023 M16/6(Throttle valve actuator)Signal 1 ----- 1.00V
024 M16/6(Throttle valve actuator)Signal 2 ----- 4.24V
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check electronic accelerator(Idle speed):
Frame 1/1:
004 Engine speed ----- 691rpm
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check engine when driving(full throttle):
Total Frames: 1 , Supported Items: 7
Frame 1/1:
001 Temperature of coolant ----- 89°C
379 Oil temperature ----- 76°C
380 Oil level(Engine at idle) ----- 32mm
380 Oil level(Engine not running) ----- 32mm
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check further actual values:
Total Frame: 1 , Supported Items: 8
Frame 1/1:
009 Load correction factor ----- 0.98
017 Fuel tank pressure difference(USA) ----- -1.57mbar
026 S16/6(kickdown switch) ----- Not Operated
345 Exhaust temperature with TWC model ----- 428°C
614 Coolant temperature(ADC) ----- 0.67V
615 Intake air temperature(ADC) ----- 1.91V
616 Intake manifold pressure(ADC) ----- 1.41V
617 Fuel tank pressure difference(ADC)(USA) ----- 2.92V
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check self - Adaptation:
Total Frame: 1 , Supported Items: 15
Frame 1/1:
001 Temperature of coolant ----- 91°C
008 B28(Intake manifold pressure sensor) ----- 355.63mbar
181 Self-adaptation enabled ----- NO
379 Oil temperature ----- 78°C
380 Oil level(Engine at idle) ----- 32.31mm
380 Oil level(Engine not running) ----- 32.31mm
576 Selfadapation in idle speed range, right BANK of cylinders ----- 0.12ms
596 Selfadapation in idle speed range, left BANK of cylinders ----- 0.11ms
577 Self-adapation in lower partial-load range, right BANK of cylinders ----- 1.00
597 Self-adapation in lower partial-load range, left BANK of cylinders ----- 1.00
578 Self-adapation in upper partial-load range, right BANK of cylinders ----- 1.00
598 Self-adapation in upper partial-load range, left BANK of cylinders ----- 1.00
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check sensor adaptation:
Total Frames: 1 , Supported Item: 1
Frame 1/1:
114 The sensor rotor adaption in the load range 2 and the engine speed range 1 is learned, Basic adaptation must be performed in this range for the smooth engine running test ----- NO
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Check smooth engine running:
Frame 1/1:
001 Temperature of coolant ----- 93°C
379 Oil temperature ----- 80°C
380 Oil level(Engine at idle) ----- 32.63mm
380 Oil level(Engine not running) ----- 32.94mm
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Exhaust emissions test(AU):
Total Frame: 1 , Supported Items: 5
Frame 1/1:
004 Engine speed ----- 688rpm
042 Idle speed detection ----- OFF
608 Lambda control, before TWC right ----- 0.99
610 Lambda control, before TWC left ----- 1.00
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Falut counter:
Frame 1/1:
550 Engine speed ----- 675rpm
552 Fault counter of cylinder 1 ----- 0
553 Fault counter of cylinder 4 ----- 0
554 Fault counter of cylinder 3 ----- 0
555 Fault counter of cylinder 6 ----- 0
556 Fault counter of cylinder 2 ----- 0
557 Fault counter of cylinder 5 ----- 0
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Individual actual value group:
Total Frame: 1 , Supported Items: 24
Frame 1/1:
002 Temperature at engine start ----- 143°C
003 B17/8(Charge air temperature sensor) ----- 37°C
005 Engine specified speed(Idle speed) ----- 694rpm
007 Air mass ----- 12kg/h
068 B28(Pressure sensor) ----- 350.24mbar
012 Torque ----- 57.19Nm
025 S40/3(Clutch pedal switch) ----- Not Operated
044 Selector lever position ----- P,N
186 Cruise control ----- OFF
188 Cruise control switch accelerate ----- OFF
189 Cruise control switch decelerate ----- OFF
190 Cruise control switch store ----- OFF
191 Cruise control switch off ----- ON
192 Safety contact for Cruise control switch ----- OFF
193 Cruise control shutoff by function processor ----- YES
194 Cruise control shutoff by back-up processor ----- NO
195 Cruise control switched off by ESP ----- NO
214 Variable speed limit [km/h] ----- OFF
218 Y80(Cylinder shut-off valve, right BANK of cylinders), Inlet valves ----- OFF
219 Y81(Cylinder shut-off valve, left BANK of cylinders), Inlet valves ----- OFF
227 Exhaust flap control ----- OFF
380 Oil level ----- 33.25mm
618 HFM-SFI voltage ----- 1.38V
198 Number of engine starts until self-interlocking of the engine control module ----- 79
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Knock sensor system:
Total Frame: 1 , Supported Items: 9
Frame 1/1:
048 Knock control enable ----- NO
389 Engine speed ----- 700rpm
390 Engine load ----- 18%
391 Knock ignition angle of cylinder 1 ----- 0°
392 Knock ignition angle of cylinder 4 ----- 0°
393 Knock ignition angle of cylinder 3 ----- 0°
394 Knock ignition angle of cylinder 6 ----- 0°
395 Knock ignition angle of cylinder 2 ----- 0°
396 Knock ignition angle of cylinder 5 ----- 0°
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Lambda control, downstream TWC:
Frame 1/1:
038 Component G3/6(Right O2 sensor, after TWC [KAT])is operational ----- YES
039 Component G3/5(Left O2 sensor, after TWC [KAT])is operational ----- YES
345 Exhaust temperature with TWC model ----- 404°C
604 G3/6(Right O2 sensor, after TWC[KAT]), signal ----- 722.44mV
606 G3/5(Left O2 sensor, after TWC[KAT]), signal ----- 722.44mV
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Lambda control, upstream TWC:
Frame 1/1:
215 Lambda control, before TWC right ----- ON
225 Lambda control, before TWC left ----- ON
600 G3/4(Right O2 sensor, before TWC [KAT]), Signal ----- 707.69mV
602 G3/3(Left O2 sensor, before TWC [KAT]), Signal ----- 92.41mV
608 Lambda control, before TWC right ----- 1.02
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Preconditions Smooth engine running - Fault counter:
Frame 1/1:
045 Air conditioning ----- OFF
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Smooth engine running:
Frame 1/1:
619 Engine speed ----- 675rpm
641 Smooth running of cylinder 1 ----- 0L/s²
642 Smooth running of cylinder 4 ----- 0L/s²
643 Smooth running of cylinder 3 ----- 0L/s²
644 Smooth running of cylinder 6 ----- 0L/s²
645 Smooth running of cylinder 2 ----- 0L/s²
646 Smooth running of cylinder 5 ----- 0L/s²
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Test electric fan for engine and air conditioning:
Total Frame: 1 , Supported Items: 3
Frame 1/1:
376 Fan capacity request by engine ----- 13.33%
377 Fan capacity request by air conditioning ----- 0%
378 Fan capacity, effective(on/off ratio) ----- 13.33%
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Test engine at idle speed:
Frame 1/1:
001 Temperature of coolant ----- 92°C
379 Oil temperature ----- 88°C
380 Oil level(Engine at idle) ----- 33.57mm
380 Oil level(Engine not running) ----- 33.57mm
381 Oil quality ----- 2.16
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Test values at idle speed:
Total Frame: 1 , Supported Items: 13
Frame 1/1:
003 B2/5b1(Intake air temperature sensor) ----- 40°C
004 Engine speed ----- 674rpm
008 B28(Intake manifold pressure sensor) ----- 361.02mbar
010 Throttle valve angle ----- 1.58°
011 Ignition angle ----- -17.24°
013 Injection time, right ----- 3.45ms
014 Injection time, left ----- 3.50ms
018 On/off ration of purge control ----- 9.41%
217 Purge control ----- ON
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data:
Frame 1/1:
019 Vehicle speed left front axle ----- 0km/h
020 Vehicle speed left rear axle ----- 0km/h
187 S9/1(Stop lamp switch) ----- OFF
Total Number : 1
P2030-004 1/1
State: Current
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>Module Information:
Control Unit: ETC
Supplier: Siemens
MB Number: 0305452332
Hardware Status: 03/01
Software Status: 42/01
Diagnosis Identification: 02/00
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>Read Fault Code:
Total Number : 1
P2313 1/1
State: Current
There is a fault in CAN communication with control module N15/5(Electronic selector lever module control module) or the selector lever position of control module ESM is unreasonable
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Emergency running:
Frame 1/1:
019 Emergency running ----- YES
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Solenoid valves:
Total Frames: 2 , Supported Items: 9
Frame 1/2: Not Running
040 Set current of component Y3/6y1(Modulating pressure control solenoid vlave) ----- 783mA
041 Set current of component Y3/6y2(Shift pressure control solenoid valve) ----- 982mA
042 Actual current of component Y3/6y1(Modulating pressure control solenoid valve) ----- 1mA
043 Actual current of component Y3/6y2(Shift pressure control solenoid valve) ----- 0mA
044 Status of shift valves ----- 1 - 2 or 4 - 5
045 Pressure of component Y3/6y2(Shift pressure control solenoid valve) ----- 0mbar
046 Pressure of component Y3/6y1(Modulating pressure control solenoid valve) ----- 750mbar
097 On/off ratio of torque converter lock-up ----- 01/255
Frame 2/2: Engine Running
040 Set current of component Y3/6y1(Modulating pressure control solenoid vlave) ----- 818mA
041 Set current of component Y3/6y2(Shift pressure control solenoid valve) ----- 0mA
044 Status of shift valves ----- Not present
045 Pressure of component Y3/6y2(Shift pressure control solenoid valve) ----- 7700mbar
046 Pressure of component Y3/6y1(Modulating pressure control solenoid valve) ----- 500mbar
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Speeds:
Total Frames: 1 , Supported Items: 9
Frame 1/1:
003 Target gear ----- IMPLAUSIBLE
004 Actual gear ----- IMPLAUSIBLE
032 Transmission output speed ----- 0rpm
001 Y3/6n2(speed sensor 2) ----- 685rpm
002 Y3/6n3(speed sensor 3) ----- 674rpm
021 Engine speed ----- 696rpm
031 Turbine speed ----- 687rpm
080 Vehicle speed at rear axle ----- 0km/h
081 Vehicle speed at front axle ----- 0km/h
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Start operation:
Total Frames: 1 , Supported Items: 2
Frame 1/1:
016 Y3/6s1(Starter lockout contact) ----- Open
050 Selected gear by means of selector lever(CAN) ----- Unknownstatus
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Switches:
Frame 1/1:
013 S16/6(kickdown switch) ----- Not Operated
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Torque converter lockup clutch:
Total Frames: 2 , Supported Items: 8
014 Transmission oil temperature in selector lever position R or D ----- 89°C
020 Status of lock-up clutch ----- Open
060 Speed difference of lockup clutch ----- 0rpm
014 Transmission oil temperature in selector lever position R or D ----- 83°C
060 Speed difference of lockup clutch ----- 8rpm
BENZ_EN_TEST_00006>CLK(208)>208.465 - CLK320>Manual>TCM - Transmission Control Module>View Data>Upshift and downshift:
Frame 1/1:
011 Selected gear by means of selector lever ----- Unknownstatus
049 Driving style factor(FZI) ----- 0
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>Module Information:
Control Unit: ABS
Supplier: Bosch
MB Number: 0315450732
Hardware Status: 42/00
Software Status: 14/00
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>Read Fault Code:
Total Number : 4
C1200-008 1/4
State: Historic
S9/1(Stop lamp switch): Plausibility
C1200 2/4
State: Historic
C1504-009 3/4
State: Current
System faults: Steering angle sensor is not initialized
C1504 4/4
State: Current
System faults
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>View Data>Brake assist:
Total Frames: 5 , Supported Items: 5
Frame 1/5:
02 Brake pressure sensor ----- 0bar
03 Stop lamp switch NO contact ----- OFF
01 Diaphragm travel ----- 6.08mm
04 Release switch NO contact ----- OFF
05 Release switch NC contact ----- ON
Frame 2/5:
02 Brake pressure sensor ----- 82.67bar
Frame 3/5:
Frame 4/5:
Frame 5/5:
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>View Data>CAN signals:
Frame 1/1:
01 Engine speed ----- 689rpm
02 Model ----- N/A
03 Motor electric emergency running ----- NO
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>View Data>ESP sensors:
Total Frames: 11 , Supported Items: 3
Frame 1/11:
01 EPS yaw rate sensor ----- -0.54°/s
03 Lateral acceleration sensor ----- 0.19m/s²
04 Steering angle sensor ----- 5°
Frame 2/11:
01 EPS yaw rate sensor ----- -0.27°/s
Frame 3/11:
01 EPS yaw rate sensor ----- -0°/s
03 Lateral acceleration sensor ----- 0m/s²
Frame 4/11:
Frame 5/11:
Frame 6/11:
Frame 7/11:
Frame 8/11:
Frame 9/11:
Frame 10/11:
Frame 11/11:
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>View Data>Signals:
Frame 1/1:
05 ESP OFF switch S76/6 ----- 0V
04 Circuit 87 ----- 12.56V
01 Stop lamp switch NO contact ----- OFF
02 Stop lamp switch NC contact ----- ON
03 Parking brake indicator ----- OFF
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>ABS - Traction Systems(ABS-ASR-ETS-ESP)>View Data>Vehicle speeds:
Total Frames: 2 , Supported Items: 4
Frame 1/2:
01 Front left speed ----- 652.80km/h
02 Front right speed ----- 2.55km/h
03 Rear left speed ----- 0km/h
04 Rear right speed ----- 0km/h
Frame 2/2:
01 Front left speed ----- 650.24km/h
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>SRS - Supplemental Inflatable Restraint System>Module Information:
Control Unit: AB
Supplier: Bosch
MB Number: 0018200826
Hardware Status: 12/95
Software Status: 07/97
Diagnosis Identification: 04/01
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>SRS - Supplemental Inflatable Restraint System>View Data>All datastream:
Frame 1/1:
Airbag ignition circuit Driver ----- OK
Airbag ignition circuit Front passenger ----- OK
Belt buckle airbag, etensioner retractor Driver ----- OFF
Belt buckle airbag, etensioner retractor Front passenger ----- OFF
Driver side airbag sensor ----- OK
ETR ignition circuit Driver ----- OK
ETR ignition circuit Front passenger ----- OK
Passenger side airbag sensor ----- OK
SRS airbag malfunction indicator lamp A1e15 ----- OK
Seat occupied recogn ----- ON
Sidebag ignition circuit Driver ----- OK
Sidebag ignition circuit Front passenger ----- OK
Voltage ----- OK
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>IC - Instrument Cluster>Module Information:
Control Unit: KIL
Supplier: VDO
MB Number: 2085405811
Hardware Status: 17/07
Diagnosis Identification: 03/06
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>IC - Instrument Cluster>View Data>Active service system before last oil change- 1, Data set of oil change table:
Total Frame: 1 , Supported Items: 6
Frame 1/1:
Product of quality factors ----- N/A
Reading of main odometer ----- 266300km
Remaining distance ----- 5079km
Remaining time ----- -983d
Service ----- MINOR
Total of replenishments ----- N/A
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>IC - Instrument Cluster>View Data>Instrument cluster - Pushbutton:
Frame 1/1:
A1e7(Low brake fluid parking brake warning lamp) ----- OFF
A1s4(Instrument and switch lighting bright pushbutton) ----- OFF
A1s5(Instrument and switch lighting dark pushbutton) ----- OFF
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>AAC - Automatic Air Conditioning>Module Information:
Control Unit: ACC
Supplier: GKR
MB Number: 1408302685
Hardware Status: 24/98
Software Status: 24/98
Diagnosis Identification: 02/22
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>AAC - Automatic Air Conditioning>View Data>GENERAL DATA:
Total Frame: 1 , Supported Items: 14
Frame 1/1:
AC compressor control valve ----- N/A
Aspirator fan capacity ----- N/A
Blending air flap servo motor ----- N/A
Coolant temperature ----- N/A
EMERGENCY OFF A/C compressor signal ----- N/A
Engine speed ----- N/A
Engine speed increase ----- N/A
Evaporator temperature ----- N/A
Fresh air/recirculated air flap servo motor ----- N/A
Full load cut-off A/C compressor ----- N/A
In-car temperature ----- N/A
Outside air temperature ----- N/A
Refrigerant pressure ----- N/A
Tml 58d ----- N/A
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>EIS - Electronic Ignition Switch ELCODE>Module Information:
Control Unit: EIS
Supplier: Marquardt
MB Number: 2105450208
Hardware Status: 12/00
Software Status: 42/98
Diagnosis Identification: 00/09
BENZ_EN_TEST_00009>CLK(208)>208.465 - CLK320>Smart Scan>EIS - Electronic Ignition Switch ELCODE>Read Fault Code:
Total Number : 1
B1058 1/1
State: Current
Fault in CAN communication with: UBF N72
