To replace maf or not
Old Jan 6, 2007 | 01:30 PM
01clkcabrio's Avatar
My car feels like it has the power but sometimes it is weak like the motor does not pull .i get average 17-20 mioles per gallon and in the moring the car tells me 10 miless per gallon.what you think
Old Jan 6, 2007 | 02:14 PM
SeNia_CLK's Avatar
2001 CLK 320
I think you should research more...but I think you and me have the same problem at the moment and it sounds like the MAF needs to be replaced. I am waiting for an OBDII code reader right now to make sure my codes are actually what I predict they are. Anyways man good luck with that it's some what pricey
Old Jan 7, 2007 | 12:17 PM
Serndipity's Avatar
2001 CLK320 Cabrio
[i get average 17-20 mioles per gallon and in the moring the car tells me 10 miless per gallon.what you think]
Mileage depends of type of driving (and driver type), engine size etc.
For reference, I get 30MPG on a trip and 27MPG mixed city/highway and 23MPG all local with my 2001 CLK320 Cab..
I would go the AutoZone, Advanced Auto and see if you have any OBCCII codes (it's a free service). Believe the MAF codes are P0170, P0173. However, you CEL would be on as well, so you most likely don't have a MAF problem at this time.
Changing the MAF is a 5 minute job and requires only a screwdriver.
However, they aren't cheap.
Old Jan 7, 2007 | 10:41 PM
bm1984's Avatar
2002 CLK 430
what is a MAF
Old Jan 8, 2007 | 08:01 PM
SeNia_CLK's Avatar
2001 CLK 320
Ok man, here is an idea... it doesn't necessarily mean its a MAF problem... when was the last time you looked at your spark plugs or cables? Might want to check it out before dashing out for the MAF. O2 might also be a problem... the best thing for you to do right now is to find a OBDII plug urself in and check your codes...then you wil be able to really narrow your problems... I did and got 5 codes My 4th and 6th cylinders are misfiring...hmm sounds like a spark plug/cable problem to me!
Old Jan 8, 2007 | 08:03 PM
SeNia_CLK's Avatar
2001 CLK 320
Originally Posted by bm1984
what is a MAF
The Mass Air Flow Sensor is probably the best way to measure the amount of air an engine takes in (engine load). This sensor not only measures the volume of air but also compensates for its density as well. Cheers!
Old Jan 9, 2007 | 02:04 AM
bm1984's Avatar
2002 CLK 430
where do you find this OBDII
Old Jan 9, 2007 | 03:22 AM
E55 PWR's Avatar
e55
try cleaning it first. get 91% isopropyl and pour it on the MAF sensor (or put a few bottles in a big zip lock baggie, close it swish it around for a few min, let it try then reinstall. If that still doesn't help as much you can clean even further with the same 91% isopropyl w/ a Q-tip and carefully clean all the metal portions on the sensor. You can usually get 1-2 extra years out of an MAF this way (this is also a great way to clean your MAF if you have a K&N filter. hope that helps.
Old Jan 9, 2007 | 01:38 PM
SeNia_CLK's Avatar
2001 CLK 320
You research!
Old Jan 10, 2007 | 10:10 AM
MarcusF's Avatar
2002 CLK430
Manuals Unlimited has an OBDII code checker for $79. Here's a link.
Old Jan 10, 2007 | 11:24 AM
SeNia_CLK's Avatar
2001 CLK 320
Ebay has them for $52
Old Jan 13, 2007 | 04:39 AM
bm1984's Avatar
2002 CLK 430
so what can you do with that OBDII code reader if the dash doesnt show any malfuntions
Old Jan 13, 2007 | 04:42 AM
bm1984's Avatar
2002 CLK 430
my 02 430 also sometimes doesnt really get going at the low rpms. then sometimes like on cold mornings its noticably faster. it has 67k on it, what could be the prob there? i removed the resonator for some reason couple months ago,, dont know if that could have something to do with it,.
Old Jan 15, 2007 | 11:35 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
It's kind of a Catch22 situation. The OBDII reader will most times lead you to the part that is the culprit of a given malfuncion. However, you have to be able to decipher what the OBDII reader is 'telling' you. For instance, the text from the reader for a bad MAF (sorry, I forgot the code #s...) says something like 'Fuel Trim malfunction, Bank 1'. So unless you KNOW that this message is a bad MAF (or one going bad), you're still kind of s__ our of luck. Oh, and another gotcha is the MAF may not actually be bad. I've heard of people cleaning the MAF (with alcohol) and fixing the problem (disclaimer here. I don't know if this really works) as well as making sure it's seated proplerly.
If you get one, just post a thread with your error code here. I'm sure somebody out here can help.
Old Jan 16, 2007 | 07:23 AM
Idle Swede's Avatar
01 430 CLK, 85 RR Silver Spur, 90 Bentley Turbo R, 93 FLSTN
They also have them for $15 - $30 but all they do is turn off the light.
Old Jan 16, 2007 | 10:30 AM
SeNia_CLK's Avatar
2001 CLK 320
Wouldn't be called something else if it only turns off the light?
Old Jan 16, 2007 | 08:17 PM
Idle Swede's Avatar
I guess you'll find out when you purchase one.........
Old Jan 16, 2007 | 09:24 PM
SeNia_CLK's Avatar
2001 CLK 320
Oh no, I already did purchase one... it cost me $52CAN +$10 Shipping to Canada. Fires codes back at me, so I am sure I GOT the right one
Old Jan 16, 2007 | 10:54 PM
Idle Swede's Avatar
You are one lucky dude......
Old Jan 17, 2007 | 02:01 AM
SeNia_CLK's Avatar
2001 CLK 320
I must be!
Old Jan 17, 2007 | 02:03 AM
SeNia_CLK's Avatar
2001 CLK 320
It will work, it makes sense...but I think you'll only be able to get another week out of ur MAF and then you will have to get a new one. Trust me it has been done.
Old Jan 17, 2007 | 02:33 AM
E55 PWR's Avatar
e55
clean it w/ 91% isopropyl alcohol and a Q-tip ( or also pour a few bottles into ziplock baggie and swish around for a few min, then try and put back in the car). u can do this for the life of the MAF, this usually gets the car back to almost like new. u can get a few extra years out of a MAF by doing this, eventually it will fail but till will prevent it as much as possible.
Old Jan 17, 2007 | 12:28 PM
SeNia_CLK's Avatar
2001 CLK 320
Have you done that yourself?
Old Jan 18, 2007 | 03:57 AM
E55 PWR's Avatar
e55
of course, been doing it for years on BMW and mercedes air flow sensors. Its a great way to keep your MAF clean when using K&N filters.
Also Ebay has OBD2 readers for $39, talk about cheap. I bought one, works fantastic, looks much more $$ than it really is.
Old Jan 18, 2007 | 12:37 PM
SeNia_CLK's Avatar
2001 CLK 320
Thanks for the confirmation. Well thats good to know, because a friend of mine done that on his BMW and MAF failed 10 days later. But I'll give it a try if my MAF goes. As for OBDII I think fellow Idle Swede had a bad experience buying his... because he is convinced you can't get them so cheap.
