clk430 rear head rest issue?
Old Jan 19, 2007 | 12:32 PM
eengner's Avatar
07 E63
I can't get my passenger side rear headrest to go down. Any thoughts?
Old Jan 19, 2007 | 02:37 PM
bm1984's Avatar
2002 CLK 430
ya me too, i couldnt get one down, so i put the other one up thinking i could find out how to put it down, so now i got both of them up and cant get them down. are they f'd up or am i just not figuring out how to put them down
Old Jan 19, 2007 | 06:17 PM
Idle Swede's Avatar
01 430 CLK, 85 RR Silver Spur, 90 Bentley Turbo R, 93 FLSTN
I hit the switch and they fall down.............
Old Jan 21, 2007 | 06:32 AM
bm1984's Avatar
2002 CLK 430
what if the switch doesnt do anything , fuse?
Old Jan 21, 2007 | 12:43 PM
SeNia_CLK's Avatar
2001 CLK 320
Haha... yah me too...seems to work just fine!
Old Jan 21, 2007 | 02:09 PM
BilOutkast's Avatar
Not to sure but check the fuse, have somebody try to wiggle it around while pressing the button also.
Old Jan 21, 2007 | 07:37 PM
software's Avatar
2014 E550 Convertible
You might have to break out the sledge, or raise the other one and get used to them being up!
Old Jan 23, 2007 | 06:07 PM
eengner's Avatar
07 E63
thought so
I'm just sad that this site turned out to be useless. I thought it might be from all the threads I read.
Just sad,
Brian
Old Jan 23, 2007 | 06:10 PM
eengner's Avatar
07 E63
Go Away
Sorry for the guy who also has the problem and the one who said try the fuse. The rest of you - what's the point. It's just odd you waste time posting crap to peoples questions.
The moderator should just cut you off.
Brian
Old Jan 23, 2007 | 06:15 PM
SeNia_CLK's Avatar
2001 CLK 320
Brian
Wow man...relax a bit... I am truly sorry we can't help you with all of your problems... This has never happened to me...but everything that has happened so far I dealt with using this site as a valuable resource...made a few suggestions to other members and helped them solve their problems. Did you try searching the forum for more info?
Old Mar 16, 2007 | 01:29 PM
eengner's Avatar
07 E63
oops
I guess I did just turn into a jerk, or worse.
It's just that a few of these problems drive me crazy - and mercedes will look at the headrest for me for about $300.
I'll keep working at it.
Brian
Old Mar 16, 2007 | 03:25 PM
halik's Avatar
heh on my car, they go up whever you move the passanger seat back. Go figure
Old Mar 16, 2007 | 03:54 PM
The Jury's Avatar
2002 c240
Just sad,
Brian
Not entirely a lie. I've seen better organized sites, that is for sure. No FAQ's stickied to the top, no definitive answers in most of the threads searched, just guesses. Ironically most of the helpful threads are the ones linked to BENZworld where the real answer usually lies. That one always makes me chuckle.
This is a good site however, and lot's of good people on it, most from Benzworld also (I have noticed) since the two sites usually get double posted when someone makes a thread (you can usually get poker machine odds that it'll be on benzworld also, posted directly behind the thread here).
This site needs an FAQ at the top of this forum for the W208 with links. That would help for one. It needs to contain things like bulb size information for every bulb in the car, links to DIY repairs, a combination of all the body kit's available for the W208, wheel specs, offsets, etc....
NOW, let me get to the issue of the headrests. If you fold your rear seats down, the carpet laying over the area where the seats lock in can be pulled up to reveal the locking system for the headrests. You should note that you MAY have to remove the sides to get to a small plastic push in tab that MAY hold the carpet. I see a spot for them on the carpet when I pulled mine back, but mine did not have them and I simply pulled the carpet back as seen below. The deck lid need not be removed.
It just wraps around the metal there underneath, the sides of it will also pull out. You'll see the mechanism for your headrests, and an actuator bar that controls the lift of the headrest. If you look closely enough you'll figure out how to trigger the lock to release the headrest.
Old Jun 27, 2007 | 12:03 PM
eengner's Avatar
07 E63
Thanks, i'll check it out, i haven't been back here in a long time so the pictures links don't work. i'll let you know.
Brian
