My CLK wouldnt start, need help...
well tonight i was pumping gas at chevron, and i turn the key and again i hear the repetitive sound of the starter cranking but the engine never turns on. i try again, and nutin. i wait 10 min, and same thing. it wasnt the batter cause all lights work. checked fuses and everything is good. wait another 15 min and try again with no luck. me and my friend finally push the car by the water and air hose. after about 2 more times and some prayer, it finally started. i dropped my friend off and in no way was i gona turn off my car again. any ideas on what it can be??? im getting fed up with this clk and selling it to get a RELIABLE car is on my mind. thanks in advance with the help
This also happened to my 430 but then it got worse. Your car will also die while its running sometimes. Do a search and you will find the HOW-TO, pictures, and even part numbers for this.
Do not sell the car!!! These are good cars just have some trials and errors every now and then. Hope this helps!!
Greg
you are most likely right. i been reading about the cps for the last 30min on here. i hope its not the fuel pump or something more expensive. one thing that i didnt experience however, it that once it turned on, it didnt turn off on me. i drove it for 30minutes at 65mph to get home. i know for sure engine got Hot, but it didnt shut down. and i been reading that if its the cps,it suppose to shut down?
Greg
The same problem happened to me two weeks ago. I tried to start the engine few times but failed to. The starter worked very well then. One hours later, I tried again and it worked this time. Then I drove to the service shop and they did the replacement of CPS for me. Unfortunately, it happened again this evening and it could not be started even I have tried around ten times.I tried the next day. Still failed.
Anyone has other advise? Thanks a lot.
Thanks to everyone on here for the help and advice. I REALLY appreciate it. so changing the CPS is only goin to cost me about $80, which is great. i recommend if your CPS has been used for over 100k miles, change it before it goes bad. you dont want to get stranded like i did.
so all the stock CPS are defective?
no i decided since its a common problem with all clks and only an 80 dollar fix, i'll stay with it. the 208 body style is too dam good lookn too. if it had been something else and more expensive, i would have definately sold it
I'm getting somewhat offers for my biatch so we'll see how it goes..
