tune up
Old Jun 21, 2007 | 09:11 PM
SETSEROCK's Avatar
HPF E46 M3 Turbo, LET C32 AMG
tune up
tomorrow i am changing the spark plugs and changing the oil. im sure this has been asked a 1000 times, but what plugs should i use, and what kind and weight oil do i use?
thanks
Old Jun 21, 2007 | 09:54 PM
Jessica90's Avatar
BMW
You should use Mobil 1 synthetic oil 0W/40
Use either Bosch or NGK spark plugs.
Old Jun 22, 2007 | 01:11 AM
SETSEROCK's Avatar
what is the difference between platinum and iridium plugs? can anyone recommend was has worked well for them (oil and plugs) and, maybe, what i should stay away from?
Old Jun 22, 2007 | 01:14 AM
MarcusF's Avatar
2002 CLK430
I'm with Jessica on the oil - Mobil1 Synthetic 0W/40, and I would highly recommend a factory fleece filter.
When I did my plugs I bought them from the dealer. With the Mercedes Benz Club of America discount, they were $7.50 each. Bosch FR8DPP33 plugs, the Mercedes part number is 004-159-19-03-26.
I'd highly recommend using spark plug wire pullers. If the wires are not pulled by the boot, you may have to buy new wires as well.
IHTH
Old Jun 22, 2007 | 01:47 AM
jalberto's Avatar
CLK 430
NGK Iridium spark plugs will do the job. I even got better gas mileaga after changing mine. Cost me about $100 for the 16 sparkplugs. Careful with hte wires...those are really expensive
Old Jun 22, 2007 | 03:24 PM
wnycec's Avatar
2000 CLK 430
would you use 0W 40 oil for a car with 70k+ mileage?
anyone have the part number for motor mounts and the O2 sensor?
Thanks in advance.
Old Jun 26, 2007 | 02:25 PM
wnycec's Avatar
2000 CLK 430
bump
Old Jun 26, 2007 | 03:10 PM
krayzie_e99's Avatar
2000 CLK 320
how bout goin with the bosch fusion. they have plat. and iridium. they about 10 bucks a plug tho
Old Jun 26, 2007 | 05:03 PM
MarcusF's Avatar
2002 CLK430
Thanks in advance.
Yes, I do use 0W/40 Mobil1, and I have 70K+. The last time I changed oil was January 5th, 8500 miles ago, and haven't had to add any since.
The motor mounts are 202-240-29-17.
Old Jun 26, 2007 | 08:27 PM
nrkmann's Avatar
Smile 0W-40 at 70K?
Yes, and at 225K in my 300SDL. Uses a quart every 5K or so... nrk
Old Jun 28, 2007 | 03:52 PM
ckanderson's Avatar
Clk 430
I'm not sure if this is allowed, feel free to delete this if it isn't.
If anyone is interested, I have a line on bosch factory replacement plugs.
Normaly with the MB discount they are 7.50 a piece. I can get them to you for only 6.25 a plug. This equils exactly 100 dollars, plus shipping (under 8 dollars). If anyone is interested PM me please.
