Window problem
Old Oct 18, 2002 | 03:31 PM
robertl's Avatar
Window problem
My driver-side window doesn not want to close all the way up. Was there any solution to this, aside from going to the dealer to have it reset?
I am sorry to post this much discussed problem again, but I could not find any info on it on the forum in the timely manner.
Thanks Much,
Robert L
Old Oct 18, 2002 | 03:35 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
you can resync yourselclose the windows with the summer feature,then open with the summer feature ,then try that window by itself
Old Oct 18, 2002 | 03:37 PM
robertl's Avatar
I am sorry, but what does the "summer feature" mean?
Old Oct 18, 2002 | 03:46 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
if you are talking about it not wanting to 'auto-up' all the way... just hold down the 'up' button after it reaches the top for a few seconds... and that will reset the windows.
Old Oct 18, 2002 | 03:49 PM
DSMIT's Avatar
the summer feature is when you depress the lock or unlock on the remote and the windows will open and close
Old Oct 18, 2002 | 04:05 PM
LowRydeR's Avatar
Have the dealer fix the problem for you.
-Bruce
Old Oct 19, 2002 | 03:39 AM
Mach430's Avatar
The reason you are getting 2 different responses is because there are actually 2 different problems that commonly occur with the windows. Before you go to a dealer, I recommend that you try resetting the controller by following mmgrad's instructions. If this doesn't work, than the regulators may be broken, and the dealer will likely replace the window motor (had mine done twice).
Old Oct 20, 2002 | 03:19 AM
JohnnyBoy's Avatar
01 CLK430
Me Too
Hi,
I'm having similar problems in my 2001 CLK 430 where the Express Up hit's the top of the window and opens a few inches back down. It thinks something is in the way. My friend said go in and have the control modules replaced for each door.
Also, isn't the driver window suppose to open slightly when the door is opened and then reseal after it's closed?
Thanks for the responses. I'm a new owner trying to figure out what the windows should and shouldn't do.
John
Old Oct 20, 2002 | 01:38 PM
Mach430's Avatar
Sounds like your window just needs to be reset. Press the button 1 click (Not all the way) so that it lowers to the bottom. Then hold the button all the way down for 7 seconds. Do the same for the way up. This should fix your window. If not, the dealer will need to replace it.
Old Oct 20, 2002 | 03:02 PM
mmgrad's Avatar
Re: Me Too
John
Yes this is normal....
MBs with no top window frame will lower the glass when the doors open, and raise it back up when the windows close. better noise and weather insulation.
