Power seat failures
I don't really notice it since not only do I not have rear seat passengers, but I rarely have any passengers in the car with me. But in a $60K car, shouldn't everything work? What a bummer.
How many of you guys have this problem? What did the dealer say was the problem and did they fix it successfully?
I'm just learning to live with it.
Bummer. At least the car is fast.
well, i had a problem where the seat wouldn't go up/down, and the forward-scoot function.
They replaced some part of the motor and everything was cool.... UNTIL... the seat somehow reset itself to stop at a different position when it suppose to scoot forward. took it in, and they reset the stop point. I think it was my fault, cause on more than one occasion I would have a water bottle stuck under the seat, having the seat crush it when it slides forward...
I now leave all water bottles in the rear between the seats... and no problems since
another thing to check.. which confused my jag dealer for 2 days... check for small coins in the seat runner.
I checked this out and it seems to be true (i.e. when the front seat is way back, it slides forward and when it is more forward, it does not).
Can someone try this on another CLK to see if the same happens?
I thought I had a problem with the front seat no longer moving forward to allow access to the back seat and had my dealer check it out. They said that the seat only moves forward if the person using the front seats have them set back fairly far (i.e. for more leg room).
Here's a question. When you move the seat backwards when sitting in it, the headrest goes up. But when you move the seat forwards, shouldn't the headrest slide downwards? Mine just keeps going up no matter what direction I slide.
$80k P.O.S.
/ducks
