Rim Fitment Issuee Help pleasseee...
Old Nov 16, 2007 | 02:26 AM
clkmilad's Avatar
2002 clk 430
02 clk 430 Rims are Stern hypermesh 19 by 9.5 rear 8.5 front all with 35 offset, the rear fit fine but the front wont go on properly due to the "Grease cap" i believe they have 2.5 front lip if somone can tell me the problem or how i can remove the grease caps or willl i need spacers pleassse tell me ???
Old Nov 16, 2007 | 03:33 AM
OPALW208's Avatar
SL55, C63
what is a "grease cap?"
Old Nov 16, 2007 | 04:46 AM
CurYousGee's Avatar
2000 CLK 430
sounds like the center cap???? or the hub??? who knows
Old Nov 16, 2007 | 02:00 PM
clkmilad's Avatar
2002 clk 430
https://mbworld.org/forums/wheels-tires-suspension-brakes-forum/218656-help-fitment-issue-w208-19-s.html Here is the link to the picture i took with my rim off, its the sillver hub in the middle, the rear ones did not have the cap or hub or whatetever it s.... Anbody think they know what it is ???
Old Nov 16, 2007 | 04:29 PM
430cruz's Avatar
'99 CLK430
That is the front spindle bearing dust cap. It pulls out with a large pair of channel locks or use a flat blade screw driver and work around the lip like your prying off a paint can lid. Behind it is the bearing and race assy. and you may also find a decent portion of the front spindle sticking out.
If this is the case then the dust cap needs to be dome shaped. If the end of the spindle does not extend past the dust cap rim the have an autoparts store match the diameter but with a flat dust cap, or more shallow dome.
Hope this makes sense.
Old Nov 16, 2007 | 04:55 PM
rogan1's Avatar
clk430
Which area do you pry from to get the cap off? I labeled the areas, is it 1 or 2?
http://home.comcast.net/~danavon7/cap.jpg
Old Nov 16, 2007 | 05:04 PM
tpick23's Avatar
E63
number 1
Old Nov 16, 2007 | 06:52 PM
clkmilad's Avatar
2002 clk 430
This should be in the diy section, i mean i did a search and couldnt find anything on how to remove the dust cap properly....Neways thanks a lot im gonna take another try at it with my tools, thanks
Old Nov 17, 2007 | 11:35 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
i hjad the same problem and just hammered them in a little bit...
