Another Oil Change Question
Used to be a CLK430
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hey guys,
I posted this on the Tech forum but haven't received any responses yet....anyone care to help??
I hate to ask another question about DIY oil changes, but I'm just not finding the info I'm looking for in the archives.
1. I live in Houston, TX ~ what kind of oil should I be using? The dealer used 20W50 (don't know the brand) according to my last service order.
2. Where is the oil filter located...pics would be extremely helpful if possible!!
3. Where can I buy an oil filter (besides the dealer) and what brand do to buy?
Thanks in advance!
Thanks in advance!
Re: Another Oil Change Question
Originally posted by nickv
Hey guys,
Thanks in advance!
Hey guys,
Thanks in advance!
2. Upright cylinder towards the front of the engine, big black cap, unwind it and lift it up and there's the filter...just remember to change the rubber rings as well,
3. Any auto parts store.
If you are following the FSS schedule, definitely use a synthetic...a regular oil isn't going to last for the 10 to 12,000 miles. The class action suit involving the ML was based on Mecedes not requiring the synthetic oil.
But if he's been using regular oil all along, then switching to synthetic might cause him to have oil leaks.
And I think it's '99 and before that had regular oil, if I'm not mistaken.
1 Post
'02 SLK32 AMG
There is a little leaflet called "Factory Approved Service Products" available from your dealer that lists all of the approved oils and viscosities (based on climate) for all 1998 and newer M-Bs with FSS. If you bought the car new, MBUSA mailed you the leaflet in March 2000, although it's been updated since then.
The most current list I have is from July 2001 and it lists the following oils
Mobil 1 Tri-Synthetic 0W-40
Mobil 1 Tri-Synthetic 15W-50
Valvoline SynPower Full Synthetic 5W-50
Castrol Syntec 5W-50
Castrol Syntec 10W-40
Quaker State Full Synthetic European Formula 5W-40
Pennzoil Synthetic European 5W-40
76 Pure Synthetic 5W-40
Castrol TXT Softec Plus 5W-30
Shell Helix Ultra 5W-30
Shell Helix Ultra 5W-40
Obviously, this list is out of date since Mobil 1 Tri-Synthetic was replace with Mobil 1 SuperSyn several months ago.
FYI, all AMG cars come from the factory with Mobil 1 0W-40 and that particulare grade is approved by M-B for all climates. It's available at AutoZone stores for $4.99/quart.
The oil filter is on the top front driver's side of the engine. There's a black plastic cap about 3-or 4-inches in diameter. You have to unscrew that cap and the filter cartridge is underneath. There's a tool that looks like a big socket for unscrewing the cap. You can buy a nice aluminum one at the dealer for about $10 or you can buy a plastic one at just about any auto parts store for $5.
Just buy the filter from the dealer. You probably won't find one anywhere else locally without having to order it.
Safet, Fully-Synthetic oil is required for all 1998 and newer M-B models. Also, synthetic oil does not cause leaks, and it hasn't even been proven that it will make existing leaks worse.
Brian,
I think someone wrote that a car that's been running regular oil, switching to synthetic might cause it to leak from minor imperfections that regular oil couldn't leak from?
1 Post
'02 SLK32 AMG
Originally posted by Safet
Brian,
Brian,
do a search on oil changes on this thread. I found a few links with pictures to a SLK 320 and an E320 both undergoing oil changes. I printed out the instructions and had them next to me the first time I changed my own oil.
I bought the Mobil 1 OW40. My 430 uses 8.5 quarts according to the manual.
