Clk430 Rev Limiter
Old Mar 16, 2008 | 06:36 PM
tastoto's Avatar
ck430 2002
Clk430 Rev Limiter
Hello everyone
Does anyone know how to get rid of the rev limiter on a clk430 it only revs at 4000rpm.
Old Mar 16, 2008 | 07:43 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Just a wild guess: Does it only limit you when you are in Park or Neutral? If so, I think all MBs have that as a safety feature. If when you are driving the car you are limited to 4000 RPM then that is definitely a problem. Good Luck!
Old Mar 17, 2008 | 04:58 AM
tastoto's Avatar
ck430 2002
Wink
Yes only when in park and N
Old Mar 17, 2008 | 11:46 AM
Hitman0187's Avatar
CLK430
mine doesnt stop at 4k
Old Mar 17, 2008 | 06:35 PM
tastoto's Avatar
ck430 2002
Smile
hitman how did you remove it?
Old Mar 18, 2008 | 01:19 AM
MarcusF's Avatar
2002 CLK430
First let me say that I'm not a transmission guy, and have never rebuilt one. I've done clutches in manual transmissions and replaced front and rear main seals, but that's about it. The very little I know about slush boxes but I do know the following:
Unlike in an engine, where oil always follows the same path, ATF doesn't always follow the same route. ATF typically flows from the pan through the filter, to the pump. Oil pumps are driven by the pump drive hub of the torque converter. This means when the torque converter cover is rotating, the oil pump is pumping. After the fluid leaves the pump, the flow of ATF is dictated by a part called the valve body. The first stop for the ATF in a valve body is the pressure regulator valve. A pressure regulator valve is one of the few parts I know of that exist in all automatic transmissions. However, sometimes that valve is physically separate from the valve body. At any rate, after leaving the regulator valve the fluid goes to one or more of the other valves in the valve body. The job of valve body is to regulate (hence the regulator valve) and direct fluid (the purpose of the other valves in a valve body).
The valve body, which is in charge of directing fluid, knows whether or not the transmission is in drive, or whether it's in neutral. It is entirely possible that parts which ordinarily receive "x" amount of ATF at 5 thousand RPM while in drive, only see a fraction of "x" amount of ATF while in neutral. If so, those parts which are supposed to be bathed in ATF may be severely damaged if they don't receive the correct amount of ATF.
