HEELLLLLPPPPPPP!!!! I accidentally ran my car out of gas
Old Mar 22, 2008 | 03:40 PM
1998CLK320's Avatar
1998 CLK 320
I was driving to go get gas and my car started vibrating and not accelerating when I put my foot on the gas. It started shakin and stopped and I had to get these mexicans to push me to the gas station.
The check engine light went on in between all of this.
So I got the gas and the next time I idle it starts vibrating pretty bad and I got back to my office and turned it off and then it stopped vibrating at an idle
I had my dad drive it and he thought I was crazy cuz of the idle vibrating thing cuz it wasnt vibrating when he drove it.
I just put a new MAF in and my g-ma had the back motor mounts fixed 5 years ago when she owned it.
Does anyone know what it could be?
Thank you in advance!!!!!!!!!!!
Old Mar 22, 2008 | 06:05 PM
The Jury's Avatar
2002 c240
How old are ya my friend? Most anyone with any previous car experience knows not to let a fuel injection car run out of gas. I'm gonna guess young'un.
If you are lucky enough to only need your lines purged, that won't be too horrible of a deal, but the reality is that most of the time when you run it that dry you suck sh&t into the fuel line and clog the filter - causing you to need to do a fuel filter replacement. (which before you ask is behind/beside the passenger rear wheel).
Plus now you have a CEL that needs to go in and be cleared completely from the computer - no an autozone scanner won't clear it from the computer, it will only turn the light off.
Old Mar 22, 2008 | 08:15 PM
1998CLK320's Avatar
1998 CLK 320
I'm 19 and this is my first luxury car my g-ma hooked me up at a good price
I'm used to Toyota's lol a totally different animal
Well now the car drives perfectly fine before this whole incident today.
It drives fine but the CEL is still on so how would I get a computer to clear it?
I mean I want to know for sure that it is ok but I am thinkin of disconnecting the battery and reconnecting it to see if it goes away.
I am just totally surprised that it drives fine now, I don't get it, could there still be a problem tho?
Old Mar 22, 2008 | 09:30 PM
MarcusF's Avatar
2002 CLK430
The car is 10 years old. If original motor mounts lasted 5 years, and they're 5 years old now, then there is a good possibility that they're bad again. Fluid filled motor mounts are a normal wear item.
Regarding your current problem, if the CEL is on, an error code was stored. Dump the codes and post the results.
Old Mar 23, 2008 | 11:47 AM
The Jury's Avatar
2002 c240
If it's driving properly it purged itself (lucky you). You'll still have to hook to a dealer only scanner to remove the code from the computer, a non dealer scanner will only turn the light off when you hit the clear code button making you think there is no code there.
Old Mar 23, 2008 | 11:57 AM
1998CLK320's Avatar
1998 CLK 320
I sell insurance for a living and I have absolutely no clue as to how the car works.
What does that mean that the lines are purged?
And if I get a diagnostic check and it turns the light off isn't that what I want?
