View Poll Results: Which is brighter?
OEM Xenon inside OEM Xenon Headlight
22
75.86%
Aftemarket Xenon inside OEM Halogen Headlight
7
24.14%
Voters: 29. You may not vote on this poll
OEM Xenon vs. Aftermarket Xenon
Old Dec 5, 2002 | 01:24 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
OK... have a question that hopefully you guys/gals can help me with.
In comparison between the OEM Xenon vs. Aftermarket Xenon, which is brighter. But, here is the tricky part.
Lets ASSUME the lights are equal:
Ballast & Ignitors & Starters are all same specs
Bulbs are all 5000K brightness
Which is brighter:
A.) OEM Xenon inside OEM Xenon Headlight Assembly
-OR-
B.) Aftermarket Xenon installed inside OEM Halogen Headlight Assembly
The headlight assemblies are of course different between OEM Halogen vs. Xenon version. OEM Xenon headlights have a large piece of metal inside to block and properly reflect the light as to not blind oncoming traffic. OEM Halogen headlights have a very small piece of metal.
What do you all think?
Old Dec 6, 2002 | 10:33 AM
mmgrad's Avatar
what if.....???
What if I remove the metal piece inside the stock Xenon assembly?
Would that make it a lot brighter?
And would that make it illegal (blinding oncoming traffic, etc...)?
Old Dec 6, 2002 | 11:35 PM
911Jose's Avatar
2001 CLK
mmgrad, sorry these arent answers you seek, but since we're on the topic........how come the OEM xenons turn on with a bluish tint then gradually turn white? Does this have anything to do with the metal piece mmgrad is talking about? I like the blue tint which is similar to ones you see on BMW and Acura.
Old Dec 7, 2002 | 03:15 AM
mmgrad's Avatar
Xenon is a colorless gas and the gas only appears to have color when the gas is initially ignited.
Old Dec 7, 2002 | 04:10 AM
LowRydeR's Avatar
You'll have that blue ish color if you change your Xenon bulbs to 6000K.
-Bruce
Old Dec 19, 2004 | 01:20 AM
BrabusK50's Avatar
E420 W124
Any idea where I can get the best Xenon lights for a 2001 CLK430?
Greatly appreciated.
Old Dec 19, 2004 | 11:57 AM
CERY's Avatar
The color will change when you change your Lumen output of the bulb/bulb temperature. The 5000K output should cast a simiar color output no matter what bulb you go with. The intesity of the bulb may change with the wattage of the bulbs. Assuming your ballast only puts out so many watts, you are limited to your lamp intensity.
I believe the metal piece you are talking about is the reflector. You do not want to take this out since it is what directs the beam pattern. If you remove the reflector in projector lamps, the beam pattern will not have a beam pattern and the light will just be blinding from all angles.
Old Dec 20, 2004 | 12:13 AM
BGReddy00's Avatar
I would say the best setup is oem xenon unit with phillips 6000k bulbs
Old Dec 20, 2004 | 04:44 PM
ViKTORiOUS's Avatar
W209 - W163
OEM Xenons are typically brighter than any aftermarket kit, however the aftermarket HID kits require a higher grade ballast, because the aftermarkets need more juice to operate. Aftermarket HID's are used mainly because of the color they project, all or most OEM HID kits operate at 4300k. The aftermarkets look nice but are not as bright as OEM Xenons, however people say my 8000k's are blinding when I am behind them.
Old Dec 20, 2004 | 05:51 PM
mmgrad's Avatar
wow... this thread was ressurected like 1 year after it was started...
anyhow, here's my input on my thread...
OEM headlights are best... if you want diff color, then change the bulbs. just don't go past 6000k bulbs. the factory 4300 bulbs are cleaner than halogens, but, nowhere as nice as the 6000K
after that, they start producing lots of glare. 4300-6000K has the cleanest cut-off in terms of beam pattern... and a proper headlight housing helps create that proper beam also
Old Dec 30, 2004 | 09:34 PM
Brian McL's Avatar
Retro Fit Xenon W210
I was reading this thread on the xenon lights and it is clear there are some expert out there and I need help. I just bought a set of factory Xenon headlights complete from a local auto wrecker. They appear to be in good condition and are from a 1998 E320. I want to fit them into my 97 E320, which has halogen factory lights. I noticed a couple of things different when I got them home. 1) There is an extra connector on the xenon housing which seems to attach to a motor inside the housing. I assume this is for leveling...but my originals had a sight glass with a level and not the motor: QUESTION...do I need to connect the adjusting motor and if so do I need a different light switch with a special control to activate the motor? 2) Can I just plug and play the original wiring harness into the Xenon light or do I need to replace the harness? 3) Once the lights are in do I need to go to the dealer to reset the computer? Thanks for your help...it is very much appreciated.
Old Jan 1, 2005 | 01:56 AM
mmgrad's Avatar
1.) those are the leveling controls. You won't be able to make use of that since there are additional components that you need outside of just that motor on the headlight
2.) plug 'n play is all it is... the harness plug should be the same
3.) if its a factory headlight unit, you should need anything reprogrammed from the factory.
